SVT Decomposition: Definition and Purpose
In summary, a scalar, vector, and tensor perturbation are all mathematical and physics terms used to describe changes in magnitude, direction, and linear relations between quantities. These components can be used to decompose a general symmetric metric tensor into three separate components, making it easier to work with in cosmology. The more general perturbation of the metric can be written with only two scalar functions and one vector function, as the other functions only change the scales in the metric and do not affect the physical system. Therefore, there are only 8 "important" components, and the real degrees of freedom in the metric are 6.
the_pulp
207
Hi there, I am reading about inflation, perturbations and so on, and every book I read take the SVT decomposition as granted. Something like "every perturbation can be decomposed in Scalar, Vector and Tensor perturbations". I have 2 questions:
1) What is the definition of a Scalar, Vector and Tensor perturbation? is it just a perturbation that can be written with just 1 function (Scalar) 4 functions (Vector) and 16 functions (Tensor)? or it has to behave in some why when changing coordinates? Are the numbers I wrote right or they are 1, 3 and 9 (just the space components)?
2) Why every perturbation can be wrote as a sum of Scalar, Vector and Tensor perturbations?
Thanks!
Space news on Phys.org
scalar, vector and tensor are all mathematical as well as physics terms.
-scalar is a change in magnitude only, although in physics its, a quantity that is independent of specific classes of coordinate systems
-vector is magnitude and direction, however their are numerous forms of vectors some include coordinate position
-tensors are geometric objects that describe linear relations between vectors, scalars, and other tensors, "In differential geometry an intrinsic geometric statement may be described by a tensor field on a manifold, and then doesn't need to make reference to coordinates at all. The same is true in general relativity, of tensor fields describing a physical property. The component-free approach is also used heavily in abstract algebra and homological algebra, where tensors arise naturally." cut and paste from last post wiki page
http://en.wikipedia.org/wiki/Scalar,
http://en.wikipedia.org/wiki/Scalar_(physics)
http://en.wikipedia.org/wiki/Vector_(mathematics_and_physics)
http://en.wikipedia.org/wiki/Tensor
http://en.wikipedia.org/wiki/Tensor_(intrinsic_definition)
Wikipedia has an article that goes over the details of how this works:
http://en.wikipedia.org/wiki/Scalar-vector-tensor_decomposition
Here's my description of the above article.
Perturbations in cosmology are done by taking an "average" metric (generally the FLRW metric) and adding a general symmetric metric tensor to it. But a general tensor is hard to work with: it's got 10 independent components. You can get rid of four of these by choosing the right coordinates, but that still leaves 6 components to deal with, which is difficult to understand.
The trick, then, is writing these in a way that makes sense. What was discovered back in the 40's was that one particular way of decomposing the tensor results in three separate components with different physical behavior: two scalar components, a vector component, and a tensor component. The trick is that each component has mathematical properties such that it disappears when you calculate some quantities, splitting the three components nicely in different situations.
Does that help?
I have been reading your answers, wikipedia and so on. However, I am not sure if I understood it well. Let me ask you a simple question (probably it has a simple answer and it allows me to go on). In several places (ie the Tasi lectures) it says "lets write the more general perturbation of the metric" and then he writes a metric wher the 4 terms of the diagonal depend on only two scalar functions (psi for g(0,0) and only fi for g(1,1), g(2,2), g(3,3)). If it is "the more general perturbatin" shouldn't the diagonal depend on 4 scalar (or a vector with 4 elements)? Another way to make the question is, if the metric is defined by 10 functions, shouldn't the "morge general perturbation" be defined by 10 functions?
Thanks for your answers and thanks in advance for your help!
Ps: Let me guess the answer and if it is right you just have to say yes and that´s all. We can write g(1,1), g(2,2), g(3,3) with only fi because adding other two functions only changes the scales in the metric -it is the same physical system but measured with other rules-. Am I right? If this is the case, we have only 8 "important" components? How many degrees of freedom are in the metric? 10?, 8? (I think I've read somewhere that the real degrees of freedom is 6)
Thanks again
The SVT decomposition is a mathematical tool used to break down perturbations in a given system into scalar, vector, and tensor components. A perturbation is any deviation from the expected or equilibrium state of a system. In the context of inflation and cosmology, perturbations refer to small fluctuations in the density and energy distribution of the universe.
To answer your first question, a scalar perturbation is one that can be described using just one function, while a vector perturbation requires three functions to fully describe it, and a tensor perturbation requires nine functions. These numbers correspond to the number of components in each type of perturbation. For example, a vector perturbation in three-dimensional space would have three components, one for each spatial direction.
The reason why every perturbation can be decomposed into scalar, vector, and tensor components is because these are the fundamental building blocks of the universe. In other words, all physical quantities can be expressed in terms of these three types of perturbations. This is similar to how any complex sound can be broken down into simple sine waves. By breaking down perturbations into their scalar, vector, and tensor components, scientists can better understand the underlying physical processes at play.
Furthermore, the SVT decomposition is particularly useful in the study of inflation and cosmology because it allows scientists to isolate and analyze different types of perturbations separately. This helps in understanding the effects of each type of perturbation on the evolution of the universe.
In summary, the SVT decomposition is a powerful mathematical tool that allows scientists to break down perturbations into their fundamental components, providing a deeper understanding of the underlying physical processes at play.
What is SVT decomposition?
SVT decomposition, or singular value thresholding decomposition, is a mathematical method used to reduce the dimensions of a data set by decomposing it into a lower rank approximation. This allows for easier analysis and interpretation of the data.
How does SVT decomposition work?
SVT decomposition works by taking a data matrix and decomposing it into three matrices: U, sigma, and V. These matrices contain information about the singular values, which represent the amount of variation in the data. By setting a threshold value, singular values below that threshold can be set to zero, effectively reducing the dimensions of the data.
What is the purpose of SVT decomposition?
The purpose of SVT decomposition is to reduce the dimensions of a data set while still retaining the most important information. This can help with data analysis, visualization, and interpretation. It can also be used for data compression and denoising.
How is SVT decomposition different from other dimensionality reduction methods?
SVT decomposition is different from other dimensionality reduction methods, such as principal component analysis (PCA), because it is able to handle data sets with missing values and outliers. Additionally, SVT decomposition allows for the determination of the appropriate number of dimensions, rather than relying on a predetermined number.
What types of data sets can be used with SVT decomposition?
SVT decomposition can be used with a variety of data sets, including numerical, categorical, and sparse data sets. It is also applicable to high-dimensional data sets, making it a useful tool for analyzing complex data with a large number of features.
  • Cosmology
  • Differential Geometry
