Homework Help: Swapping springs in series
  1. Oct 8, 2014 #1
    Suppose you have 2 springs in series, one is linear and one is non-linear. Initially the linear spring is at the top position and the non-linear is on bottom. Does swapping the springs affect the system?
    2. Relevant equations
    1/k_eq = 1/k1 + 1/k2
    This equation doesn't apply though since we have a non-linear spring.
    x_tot = x1 + x2
    3. The attempt at a solution
    I would say that it does not affect the system because x_tot in both cases will be equal, hence, F will be equal. x_tot = x1 + x2 = x2 + x1
    Is this correct?
  3. Oct 8, 2014 #2
    BvU
    2017 Award
    Dear user, welcome to PF :)
    If you remember where the relevant equation came from, you see that there they added the extensions: xtotal = x1+ x2 and substituted F/k1 and F/k2, respectively. So each of the springs feels the same F. That is also the case if the spring is not ideal and x is some other kind of function of F. So F isn't equal because the x_tot is equal (that is not a given; in fact that's what the exercise asks you to show!). But x_tot is equal because the F that cause the xi is the same for each spring involved, threfore the xi are equal, and yes, x1 + x2 = x2 + x1
  4. Oct 8, 2014 #3
    OldEngr63
    The same force acts through both springs (because they are in series). Each spring sees a particular deflection across that spring; the total deflection of the series pair is the sum of these deflections. The order in which the load gets to the spring is immaterial; they will experience the same relative deflections in either case. As BvU said (in different notation), d1 + d2 = d2 + d1
  5. Oct 9, 2014 #4
    Thank you. I understand now.
Have something to add?
Draft saved Draft deleted
Loading...
