Line
- 216
Throughout EE I've seen many symbols. When it comes to voltage I've seen E,V,and e. Do they all mean the same thing?
berkeman said:Sounds like your book has problems. What are the title and author of the book? Potential difference is voltage V, and [tex]E = - \nabla V[/tex]
Holy smokes, that's totally wrong and misleading. Try putting units into that equation...:grumpy:Line said:If you're counting V is the actual voltage and Eis the voltage with ground
calculated then [tex]E=V- \nabla V[/tex] ...potential difference.
Potential DIfference does eqaul voltage minus the change in voltage doesn't it?berkeman said:Holy smokes, that's totally wrong and misleading. Try putting units into that equation...:grumpy:
It can, but that's not what you wrote. There's a big difference between [tex]\nabla[/tex] and [tex]\Delta[/tex] :rofl:Line said:Potential DIfference does eqaul voltage minus the change in voltage doesn't it?
You are correct, E can be used for http://www.phys.uAlberta.ca/~gingrich/phys395/notes/node8.html [Broken].Valhalla said:E can be used for electromotive force which is equivalent to voltage right?
So in your book, they are using E interchangably with V for voltage potential. (they are virtually synonymous).Line said:In the beginning of the book they teach us E as the voltage.
I=E/R
Then in the middle they give us V.
P=VV/R
E represents electromotive force, which is the energy required to move a unit of charge between two points. V represents voltage, which is the potential difference between two points in an electrical circuit. e represents the elementary charge, which is the charge of a single proton or electron.
E and V are directly proportional, meaning that if one increases, the other increases as well. E and e are also directly proportional, as the energy required to move a charge is dependent on the charge itself. V and e, however, are independent of each other.
E is measured in volts (V), V is measured in volts (V), and e is measured in coulombs (C).
Voltage symbols, such as E and V, represent the potential difference between two points, while current symbols, such as I, represent the flow of charge through a circuit.
Understanding voltage symbols is crucial in EE as voltage is a fundamental concept in electrical engineering. It is necessary for designing and analyzing circuits, and it helps in troubleshooting and diagnosing issues in electrical systems.
