Symmetric matrix problem
In summary, the homework equations state that B has eigenvalues of 0 and 5, and that x = P*y are eigenvectors of A. The attempt at a solution found that x2*[0 1] and x2*[-2.14 1] are eigenvectors of A.f
Consider matrices A = [1 2;2 4] and P = [1 3;3 6]. Using B = P^-1*A*P, verify that similar matrices have the same eigenvalues. Find the eigenvectors y for B and show that x = P*y are eigenvectors of A.
B = P^-1*A*P,
x = P*y
I have
P^-1 = [-2 1;1 -.333]
B = [0 0;2.333 4.999]
eigenvalues for matrices A and B are 0 and 5.
eigenvectors, y are
x2*[0 1]
x2*[-2.14 1]
eigenvectors for matrix A are
x2*[-2 1]
x2*[.5 1]
P*y = [1 3;3 6]*[0 1 ; -2.14 1]
I get x = [3 .86;6 -.42]
What am I doing wrong?
similar matrices represent the same operator on a space but with different coordinates. since eigenvalues do not depend on coordinates they have the same eigenvalues.
Right, which is why I have 0 and 5 as eigenvalues for both matrices.
How do I show that x = P*y are eigenvectors of A? I feel like I'm getting the wrong answer.
B = P^-1*A*P,
x = P*y
I have
You should leave the numbers as fractions, not as rounded decimal values.
##P^{-1} =\begin{bmatrix} -2 & 1 \\ 1 & -\frac 1 3 \end{bmatrix}## and ##B =\begin{bmatrix} 0 & 0 \\ \frac 7 3 & 5 \end{bmatrix}##
eigenvectors, y are
x2*[0 1]
x2*[-2.14 1]
The latter is really ##\begin{bmatrix} -\frac{15} 7 \\ 1\end{bmatrix}##
x2*[-2 1]
x2*[.5 1]
Hard to tell what you did here. When I multiply Py, I get a matrix whose columns are vectors that are scalar multiples of ##\begin{bmatrix} -2 \\ 1\end{bmatrix}## and ##\begin{bmatrix} \frac 1 2 \\ 1\end{bmatrix}##
Your matrix of y’s on the right appears to be transposed. Might have been better off leaving them as two vectors. That would avoid this error anyway
This might not be an issue once you construct the x’s properly, but on the off chance you are asking the more basic question of “how”, you prove the x’s are eigenvectors of A by using the definition of an eigenvector
I made x2 = 1
Then I calculated P*y
This gave me
P*y = [1 3; 3 6] * [0 -15/7; 1 1] = [3 6/7; 6 -3/7]
The columns of your last matrix, Py, are multiples of ##\begin{bmatrix} \frac 1 2 \\ 1\end{bmatrix}## and ##\begin{bmatrix} -2 1\end{bmatrix}##, so they are also eigenvectors of A.
Yes, you're right. I didn't even notice that.
6*[.5 1]'
and
(3/7)*[-2 1]
Thanks! You have been a great help.
Suggested for: Symmetric matrix problem
