Exploring Symmetries and Degeneracies in Lattice Structures
  • Thread starter Niles
  • Tags
    Symmetries
In summary: Sorry for the confusion.In summary, the conversation discusses the symmetries commonly found in lattices, particularly in a 2D square lattice. These include translational symmetry, inversion, three reflection symmetries, and a four-fold rotation symmetry. These symmetries can lead to degeneracies in the system, such as the equivalence of px and py orbitals. The four reflections are longitudinal, horizontal, diagonal, and a fourth one that is not specified. There is also discussion about the distinctness of inversion and the possibility of a fourth reflection.
Niles
1,866
Hi all
What symmetries are there usually in a lattice? Let us say for example that I look at a lattice having the form (each "x" is an atom)
x x x x x x x x x
x x x x x x x x x
x x x x x x x x x
x x x x x x x x x
x x x x x x x x x
Of course there is translational symmetry (assuming homogeneous system). But what other symmetries are usually responsible for degeneracies?
If this is a 2D square lattice, you have inversion, three reflection symmetries, and a four fold rotation symmetry. Say if each atom has p orbitals on it, then px and py will be equivalent, because you have at least one symmetry operation that maps px onto py. In this case it's the 4 fold rotation, or the reflection through the [110] axis. This will make px and py degenerate.
The three reflections are longitudinal, horizontal and diagonal, right?
The four rotations are longitudinal, horizontal, diagonal and what is the fourth?
I can't see what you mean by inversion - isn't that included in the reflections?
A 4 fold rotation axis means you have an axis where you can rotate the system in steps of 360/4 degrees. Translational symmetry is compatible only with 2, 3, 4, and 6 fold rotation axes.
You are correct about the three reflection planes. And inversion in this case is the composite of the horizontal and vertical reflections. But they are distinct symmetry operations, and not every crystal which has inversion will have the other reflections.
By the way, aren't there four? Two diagonals, one vertical and one horizontal.
Yes, that's right, there should be four.
1. What are symmetries and degeneracies?
Symmetries refer to the properties of an object or system that remain unchanged under certain transformations, such as rotations, reflections, or translations. Degeneracies, on the other hand, refer to the state of having multiple solutions or states with the same energy level.
2. How are symmetries related to degeneracies?
Symmetries can lead to degeneracies because certain transformations can result in the same state or energy level. The more symmetries a system has, the more likely it is to have degenerate states.
3. Why are symmetries and degeneracies important in science?
Symmetries and degeneracies play important roles in understanding the underlying principles and properties of physical systems. They can also provide insight into the behavior of complex systems and can be used to predict and explain observations.
4. How do scientists study symmetries and degeneracies?
Scientists use various techniques and methods, such as group theory and mathematical models, to study symmetries and degeneracies in different systems. These can include crystals, molecules, atoms, and even the fundamental particles that make up the universe.
5. What are some real-world applications of symmetries and degeneracies?
Symmetries and degeneracies have applications in various fields, including physics, chemistry, and engineering. For example, understanding symmetries and degeneracies in materials can lead to the development of new and improved technologies, such as more efficient solar cells or stronger materials for construction.
  • Atomic and Condensed Matter
  • Differential Equations
