Symmetrized complex space
163
A polynomial [itex]p(z)=z^n+a_{n-1}z^{n-1}+...+a_0[/itex] has n roots [itex]\lambda_1,...,\lambda_n[/itex], and there's a map from the coefficients [itex](a_0,...,a_{n-1})\in C^n[/itex] to [itex](\lambda_1,...,\lambda_n)\in C^n/S_n[/itex], where [itex]S_n[/itex] is the symmetry group on n elements, and [itex]C^n/S_n[/itex] is complex n-space quotiented by permutations on the elements (since it doesn't matter what order the roots are in). [itex]C^n/S_n[/itex] has the quotient topology. This map [itex]C^n\rightarrow C^n/S_n[/itex] is injective because of unique factorization, surjective, and continuous, and it has a continuous inverse.
Does that mean that [itex]C^n[/itex] is homeomorphic to [itex]C^n/S_n?[/itex] That seems remarkable.
Does anybody recognize this space [itex]C^n/S_n[/itex], or know how to find out more about it?
Laura
316
[tex]\mathbb{C}^2/S_2[/tex] is an example of an http://en.wikipedia.org/wiki/Orbifold" [Broken].
Here is a geometric explanation (sort of) for why [tex]\mathbb{C}^2/S_2[/tex] is homemorphic to [tex]\mathbb{C}^2[/tex]. Under the linear transformation that maps (z,w) to (z-w,z+w), the map (z,w)->(w,z) becomes (z,w)->(-z,w), hence [tex]\mathbb{C}^2/S_2[/tex] is homeomorphic to [tex]\mathbb{C}/\{1,-1\}\times\mathbb{C}[/tex]. So the problem is reduced to showing that [tex]\mathbb{C}/\{1,-1\}[/tex] is homeomorphic to [tex]\mathbb{C}[/tex].
I will denote the real projective line by [tex]\mathbb{R}P_1[/tex].
If you map an element [tex]z\in\mathbb{C}/\{1,-1\}[/tex] to the pair
(the line spanned by z, |z|)
you get a homeomorphism to [tex](\mathbb{R}P_1\times [0,\infty))/(\mathbb{R}P_1\times \{0\})[/tex]. This is basically the half open cylinder [tex]S^1\times[0,\infty)[/tex] with the boundary circle shrunk to a point, i.e. an infinite cone, which is homeomorphic to [tex]\mathbb{C}[/tex].
Apparently it's true in general that [itex]C^n/S_n[/itex] is homeomorphic to [itex]C^n[/itex]! I found a paper online with a long, detailed proof, that seems ok as far as I've read, about why the roots of a polynomial are continuous functions of the coeffs.. It is using the quotient topology on [itex]C^n/S_n[/itex].
The map [itex]f:z\rightarrow z^2[/itex] is a homeomorphism from [itex]C^2/\{1,-1\}[/itex] to [itex]C^2.[/itex]
Laura
Here is the link to the paper about [itex]C^n/S_n[/itex] being homeomorphic to [itex]C^n[/itex].
http://arxiv.org/PS_cache/math/pdf/0502/0502037v1.pdf" [Broken]
Laura
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
