Clarifying Symmetry in Le Bellac's Quantum Physics
  • Thread starter neelakash
  • Tags
    Symmetry
In summary, the statements made in the first page of the chapter about invariance of the potential energy imply conservation of mechanical energy,momentum and angular momentum.
neelakash
511
I was going through Le Bellac's Quantum Physics book.In the "symmetry" chapter 1st page(Classical physics), he makes the following comments a part of which look a bit weired to me...Each statement starts with "Invariance of the potential energy".Do you think this is meaningful?
*Invariance of the potential energy under time-translations implies conservation of mechanical energy E = K + V , the sum of the kinetic energy K and the potential energy V .
*Invariance of the potential energy under spatial translations parallel to a vector n implies conservation of the momentum component p_n .
*Invariance of the potential energy under rotations about an axis n implies conservation of the component j_n of the angular momentum.
If he's using the Newton formulation, then he must be tacitly or explicitely assuming that:
[tex] \vec{F} = -\nabla V [/tex].
The kinetic energy usually is already invariant under the symmetries he mentiones. Therefore, if the potential energy is invariant under those symmetries, then the whole system is invariant as well.
This is a famous result called Noether's Theorem. The theorem states that if a system is related invariant with respect to a specific symmetry, then there is a specific quantity which is conserved.
E.g.
Time translation invariance <-> Conservation of (mechanical) energy
Space translation <-> Conservation of momentum
Rotation symmetry <-> Conservation of angular momentum
This is quite a statement. If you consider the collission of two particles, for instance. Suppose the force between the two particles is invariant under space and time translations. Then the theorem implies that collissions will always obey conservation of energy and momentum. And I don't even have to specify what kind of force we are dealing with!
So yes: such statements are very meaningful. But you will learn to appreciate them later on ;-)
Yes,I learned about Noether's theorm last semester...Under symmetry transformations of time translation, space translation or rotation, total mechanical energy,linear momnentum and angular momentum are conserved respectively.
My question is does the conservation of total energy,linear momentum and angular momentum imply conservation of potential energy in classical physics?I cannot see conservation of total energy/linear momentum or angular momentum would necessarily mean conservation of potential energy...
Yea...the thing is other way around,actually.There is no need to invoke Noether's theorem and its conserved current.The author puts like this: conservation of the Lagrangian [[tex]\delta\ L=0[/tex]]under space translation,time translation and space rotation gives rise to conservation of linear momentum,energy and the angular momentum.
However,whether [tex]\delta\ L=0[/tex] or not is decided by the potential function V(r1-r2)...Hence,if the potential energy is conserved,we must have [tex]\delta\ L=0[/tex] w.r.t. appropriate variables and the corresponding quantities are conserved.
1. What is symmetry in quantum physics?
Symmetry in quantum physics refers to the principles that govern the behavior of particles and systems at the most fundamental level. It is a fundamental concept that helps us understand the laws of nature and the behavior of subatomic particles.
2. What is Le Bellac's approach to clarifying symmetry in quantum physics?
Le Bellac's approach is to use group theory, a branch of mathematics, to analyze the symmetries present in quantum systems. He focuses on the symmetries of the Hamiltonian, which is the mathematical representation of a physical system.
3. How does symmetry impact our understanding of quantum physics?
Symmetry plays a crucial role in our understanding of quantum physics because it allows us to make predictions about the behavior of particles and systems. It also helps us identify patterns and relationships between different physical phenomena.
4. What is the importance of clarifying symmetry in quantum physics?
Clarifying symmetry in quantum physics allows us to gain a deeper understanding of the fundamental laws of nature and how they govern the behavior of particles and systems. It also helps us make more accurate predictions and potentially discover new physical phenomena.
5. How does the concept of symmetry relate to other principles in quantum physics?
Symmetry is closely related to other principles in quantum physics, such as the conservation of energy and momentum. It also ties in with the concept of duality, where particles can exhibit both wave-like and particle-like behavior, and symmetry plays a role in determining which behavior is observed.
  • Quantum Physics
  • Beyond the Standard Models
  • Quantum Physics
