Symmetry problem
Find the point in respect to these ellipses are symmetrical
x2 + 3y2 - 2x -2 = 0
x2 + 3y2 +6x + 12y +18 = 0
x = 2a - x'
y = 2b - y'
I have applied the equations of symmetry to the first equation then I've equaled the result to the second ellipse
4a2 + 12b2 - 4ax - 12bx - 4a -4x -20 -12y = 0
I don't know how to solve this for a and b or if I have mistaken something...
thanks
Answers and Replies
SammyS
Staff Emeritus
1,033
x = 2a - x'
y = 2b - y'
thanks
Precisely, what is it you are trying to do here?
What is the full statement of the problem?
SammyS
Staff Emeritus
1,033
Write the equation of each ellipse in standard form.
##\displaystyle \frac{(x-h)^2}{A^2}+\frac{(y-k)^2}{B^2}=1##
I'm trying to find the symmetry point of that two ellipses, it should be (-1;-1) to find it I have to solve that for a and b but how ?
SammyS
Staff Emeritus
1,033
Yes. About 5 minutes before I saw your post, I figured out what you're trying to do.
Find the point of symmetry such that if you reflect the points on either ellipse through this point of symmetry, the points will be on the other ellipse.
You have a typo in the equation:
4a2 + 12b2 - 4ax - 12bx - 4a -4x -20 -12y = 0​
That should be
4a2 + 12b2 - 4ax - 12by - 4a -4x -20 -12y = 0​
The only way to make this be zero is for the coefficients of x and of y to be zero.
[STRIKE]It looks as if there is another error. The constant term must also be zero.[/STRIKE]
Added in Edit: The constant term will also be zero.
tiny-tim
25,832
251
hi scientifico! :smile:
the two ellipses are the same shape
if you know where their centres are, isn't it obvious where the symmetry point is? :confused:
haruspex
Insights Author
2020 Award
36,163
6,782
I get a different equation. Pls post your working.
Once you have the right equation, you are looking for values of a and b that make the equation true for all x and y. (That can't work for the equation you got because the y coefficient is a nonzero constant.) Can you see how to use that?
Related Threads on Symmetry problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
