Why Is My Voltage Regulation Calculation Incorrect for a Synchronous Machine?
In summary, the conversation was about solving a problem involving a 3-phase 10kVA, 440V 60 Hz, y-connected alternator supplying a load at 0.8 power factor lagging. The given equations and attempt at a solution were shared, but there were some mistakes. The correct solution involves calculating the phase voltage, phase current, and V_LCOMP, and then using these values to find the voltage regulation, which is -45.9594%.
mayeh
This was a lecture that wasnt taught to us but we were given sample problems with answer but no solutions and i tried to solve some but ends up with wrong answer.. so here's the given:
a 3 phase 10kVA, 440V 60 Hz, y-connected alternator supplies the rated load at 0.8 power factor lagging. if the armature resistance is 0.5 and synchronous reactance is 10, find the voltage regulation at rated load. ANS: VR=48.0406%
i think this are the equations to be used:
%VR=[tex]\frac{V_{LCOMP}-V_{LRATED}}{V_{LRATED}}[/tex]*100
V[tex]_{COMP\phi}[/tex]=V[tex]_{RATED\phi}+(I_{\phi}Z_{S\phi})[/tex]
Z_{S\phi}=Re_{\phi}+JXe_{\phi}
I_{\phi}=S/(V_{L}[tex]\sqrt{3}[/tex])
THIS IS WHAT I'VE DONE:
the given voltage is line and its a star connected :V_{L}=[tex]\sqrt{3}[/tex]V_{\phi}
V_{\phi} is phase voltage
so, i solved for the phase voltage:
V_{\phi}=V_{L}/[tex]\sqrt{3}[/tex]=254.0341184V
the phase current, I_{\phi}
I_{\phi}=10kVA/(440[tex]\sqrt{3}[/tex])=13.12159703A
and
Z_{S\phi}=0.5+j10
solution:
V_{LCOMP}=[tex]\sqrt{((V_{LRATED}cos{\phi}+IR)^{2}+(V_{LRATED}sin{\phi}+IX)^{2}\[/tex]
V_{LCOMP}=[tex]\sqrt{((254.0341*0.8+13.12159*0.5)^{2}+(254.0341*0.6+13.12159*10)^{2}}[/tex]
V_{LCOMP}=352.78769V
%VR=[tex]\frac{352.78769-254.0341}}{254.0341}[/tex]*100
%VR=38.8749%
please correct my solution.. i don't have any idea if I've done this right
or wrong
Thank you for sharing your attempt at solving this problem. I can see that you have made some correct calculations, but there are a few mistakes in your solution.
Firstly, the phase voltage should be calculated as V_phi = V_L / √3 = 440 / √3 = 254.0341 V. This is because the given voltage is 440 V line-to-line, not line-to-neutral.
Next, the phase current should be calculated as I_phi = S / (V_L * √3) = 10 kVA / (440 * √3) = 13.1216 A. This is because the apparent power is given in kVA, not in amperes.
Finally, the formula for V_LCOMP is incorrect. It should be V_LCOMP = √((V_L*R + I_phi*R_e)^2 + (V_L*X + I_phi*X_e)^2). Plugging in the correct values, we get V_LCOMP = √((440*0.5 + 13.1216*0.5)^2 + (440*10 + 13.1216*10)^2) = √(225 + 19360) = √19585 = 139.8444 V.
Using this value for V_LCOMP, the voltage regulation can be calculated as %VR = (139.8444 - 254.0341) / 254.0341 * 100 = -45.9594%. This means that the voltage output of the alternator decreases by 45.9594% when the rated load is applied.
I hope this helps clarify the correct solution. Keep practicing and don't hesitate to ask for help if you encounter any difficulties in your future problem-solving. Good luck!
or wrong
I would suggest double checking your calculations and equations to ensure accuracy. It may also be helpful to consult with a professor or tutor for guidance on solving this problem. Additionally, make sure you are using the correct units for each variable and that your calculations are consistent. It is important to practice and understand the concepts behind the equations rather than just relying on sample problems and their answers.
1. How does a synchronous machine work?
A synchronous machine is a type of electric motor that operates on the principle of electromagnetic induction. It consists of a stator and a rotor, both of which have windings. When an AC current is passed through the stator windings, it creates a rotating magnetic field. This rotating magnetic field induces an AC current in the rotor windings, causing the rotor to rotate and produce mechanical power.
2. What is the difference between synchronous and asynchronous machines?
The main difference between synchronous and asynchronous machines is in the way they produce torque. Synchronous machines produce torque through electromagnetic induction, while asynchronous machines produce torque through the interaction of a rotating magnetic field and conductors in the rotor.
3. What is the purpose of a synchronous machine?
Synchronous machines are commonly used for power generation and in industrial applications, such as driving pumps, compressors, and fans. They are also used in electric vehicles and hybrid vehicles to provide traction.
4. How do you calculate the synchronous speed of a machine?
The synchronous speed of a synchronous machine can be calculated by dividing the frequency of the AC current by the number of poles in the machine and multiplying it by 60. For example, if the frequency is 60 Hz and the machine has 4 poles, the synchronous speed would be 60/4*60 = 900 rpm.
5. What is meant by excitation in a synchronous machine?
Excitation in a synchronous machine refers to the process of supplying DC current to the rotor windings to create a magnetic field. This magnetic field interacts with the rotating magnetic field of the stator to produce torque and maintain synchronization with the AC power source.
