Solving Systems of Equations: Methods and Tips for Success
  • Thread starter Markel
  • Tags
    System
In summary, the conversation discusses finding a better way to solve systems of equations with variables x, y, z, and a. The equations involve multiplication and higher powers of the variables, making the use of matrix methods difficult. The suggestion of defining y^2z^3 = b to create new equations is deemed inefficient. Instead, it is suggested to solve for a in the first three equations and substitute it into the objective function. However, it is noted that the non-negativity constraints must be taken into consideration. The question is then clarified to find the maximum value of {xy^2z^3 : 2x^2 + 3y^2 + 6z^3 = 6, x >=
Markel
84
Hello, I'm just wondering if there's a better way to solve systems such as these:
variables are x,y,z,a and I need to solve for x, y, and z.
y^2z^3 + a4x=0
2xyz^3 + a6y = 0
3xy^2z^2 + a12z = 0
2x^2 +3y^2 + 6z^2 -6 = 0
I'm aware of matrix methods to solve systems of linear equations. But for those you nead to have linear equations, correct? And here my variables are multiplied together and to higher powers.
I was thinking of definine something like y^2z^3 = b or something and just calling those terms variables, and then creating the necessary new equations. But I don't know, that seems like a lot of work.
Anyway, is there any other way to solve such systems other than back elimination of varibales and back substitution? because I have to do something like this on an exam and that method takes a lot of time, and I always make mistakes. what algorithm (if any) do you use to solve a similar system??
thanks for your help.
y^2z^3 + a4x=0
2xyz^3 + a6y = 0
3xy^2z^2 + a12z = 0
What do a4x, a6y, and a12z mean?
sorry, that was kind of unclear.
it should probably be written as:
y^2z^3 + 4xa=0
2xyz^3 + 6ya = 0
3xy^2z^2 + 12za = 0
I define a as just another variable. in the question I'm trying to do it's the lagrange multiplier but I don't know how to make a lamda, I'm trying to find the extrema, the last equation is the restriction.
Try solving for a ([itex]\lambda[/itex]) in the first three equations, starting with the second and third.
From the second equation, y(2xz3 + 6a) = 0 ==> y = 0 or a = -(1/3)xz3.
Do a similar thing for the third equation and the first. The goal is to get a number of critical points that you can substitute into the objective function.
This might work if you had multiple equations with y^2z^3, but you don't, so this is not a good idea.
BTW, this does not seem to be a precalc-level problem, so you should have posted it in the Calculus & Beyond section.
Hmm, yeah ok. that seems like a good way. I did it and it gave me the same results a bit faster. The way I initally tried was just solving for lamda from Eqn. 1 and then plugging lamda into Eqns 2 and 3.
I have a question though, you say it's 0 if y is 0 or if that expression is 0.
Does that mean later we have to check if y=0 is part of some solution?
actually, maybe I should just post my entire question, because all of it is a bit fuzzy for me.
the question is find the max of
{xy^2z^3 : 2x^2 +3Y^2 + 6z^3 = 6, x> or = 0, y > or = 0, z> or = o}So, basically I set up the equations above and muddled around with a lot of arithmatic mistakes and got this:
y= +/- 2/sqrt(15)
x= +/- sqrt(3)/sqrt(15)
z= +/- 2sqrt(3)/sqrt(15)Then I said the max was when you have either a combination of the three coordinates where x and z are their positive options, or either both their negative options,
and the minimum is when you have three coordinates where x and z do not have the same sign. does this seem somewhat correct?
Yes.
y= +/- 2/sqrt(15)
Since you have conditions that x >= 0, y >= 0, and z >= 0, you can eliminate the three negative values above. As already noted, though, some of the variables can be zero.
Markel said:
Then I said the max was when you have either a combination of the three coordinates where x and y are heir positive options, or either both their negative options,
No, due to the non-negativity constraints.
Oops, sorry.
I'm kind of new to these forums...
Anyway,
Yeah, obviously no negative solutions. Sorry, that was just an oversight on my part. Also I only need the max, so there's no minimum solution needed either.
But I'm still confused with the solution of the system of equations.
I can factor out a z from equation 3, as you did the y from eqn 2, and then I get that z=0 along with y=0 are possible solutions.
if I plug y=0 and x=0 into eqn 4, then I will get a different value for x. hmmm. Well I'm just not sure how to check these solutions. basically I'll get 4 different solution sets??, one for x,y,z >0 one for x,z>0, y=0 and one for x,y>0 z=0 and one for x>0, z,y=0
That's a lot of equations to solve...
oh, btw, thanks for helping me out. I appreciate it. I know my questions are kind of dumb but I really want to understand this problem.
If I have arrived at something like this:
x = 0 or y = 7
AND
y = 0 or z = 3
I have four things to check: x = 0 AND y = 0, x = 0 AND z = 3, y = 7 AND y = 0 (can't happen), y = 7 and z = 3.
If you add another pair of values, this doubles the number of things you need to check to 8. Each time you have to pick one from the first group, one from the second group, AND one from the third group.
I haven't worked this problem, so I'm speaking as generally as I can from that perspective.
Ok, I think I understand in general. It seems just like logic.
But I'm not sure how to apply this to the problem.
when faced with this:
I first assumed the second case, and did the same for a similar situation with z.
This led me to the solution set: y= 2/sqrt(15)
x= sqrt(3)/sqrt(15)
z= 2sqrt(3)/sqrt(15)now for instance, if I choose that actually it's y=0 and a=/= 0
then I substitute y = 0 into the system of equations and get this
0 + a2x = 0
0 + 0 = 0
0 + a12z = 0
2x^2 +6z^2 - 6 = 0which gives me the new solution set:
x = 6*sqrt(1/13)
y=0
z=sqrt(1/13) So now you're saying I need to consider
y= 2/sqrt(15) or y=0
AND
x= sqrt(3)/sqrt(15) Or x = 6*sqrt(1/13)
AND
z= 2sqrt(3)/sqrt(15) or z=sqrt(1/13) now I have to do the same for z=0
and I'll get an alternate solution set... and so I'll have
x1 or x2 or x3
AND
y1 or y2 or y3
And
z1 or z2 or z3
This seems like a huge amount of work... just to solve an system. Now I have to test every possible permutation in the constraint equation to see if it's allowed/ a maximum??
the thing is, that when I did it my way the first time. I just solved for lamda from eqn 1 and substituted back into the other two equations and rearanged, I never had to consider if y=0 and z=0. how could one method of solving give different results?
Yes, exactly like logic.
y= 2/sqrt(15)
x= sqrt(3)/sqrt(15)
0 + a2x = 0
0 + 0 = 0
0 + a12z = 0
2x^2 +6z^2 - 6 = 0
x = 6*sqrt(1/13)
y=0
z=sqrt(1/13)
AND
AND
x1 or x2 or x3
AND
y1 or y2 or y3
And
z1 or z2 or z3
Then it's possible you weren't getting all of the possible critical points. Since the goal is to get every one of these points and evaluate the objective function at each of them, if you're missing some, it's possible to overlook the true maximum point.
From the 2nd equation I got y = 0 OR a = -(1/3)xz^3
From the 3rd equation I get z = 0 OR a = -(1/4)xy^2z
There are four combinations of the pairs of equations above, and you need to investigate all four. As already stated, if you end up with another pair of equations, you'll need to look at 8 different combinations of three equations, with one from each pair.
1. What is a system of 4 equations?
A system of 4 equations is a set of four equations that are all related and need to be solved together. The solution to the system is the set of values that make each equation true when substituted into the equations.
2. How do you solve a system of 4 equations?
To solve a system of 4 equations, you can use various methods such as substitution, elimination, or graphing. These methods involve manipulating the equations in the system to find the values of the variables that make all the equations true.
3. Can a system of 4 equations have more than one solution?
Yes, a system of 4 equations can have more than one solution. This means there are multiple sets of values that satisfy all the equations in the system. However, there are also systems that have no solutions or infinite solutions.
4. What is the importance of solving a system of 4 equations?
Solving a system of 4 equations is important in various fields, especially in mathematics and science. It allows us to find the relationships between different variables and make predictions or solve real-world problems. It is also a fundamental skill in higher-level math courses.
5. Can a system of 4 equations be solved using a calculator?
Yes, a calculator can be used to solve a system of 4 equations. However, it is important to note that a calculator can only provide an approximate solution and may not be able to show all possible solutions or the steps involved in solving the system.
