System of linear equations
IniquiTrance
190
Find coefficients a, b, c, d so that the circle with the following 3 points satisfies the equation:
[tex]ax^{2} + ay^{2} + bx + cy + d = 0[/tex]
(-4, 5)
(4, -3)
(-2, 7)
I'm wondering if since I can only construct 3 equations from the 3 points, if I will have to make one unknown a parameter - probably d.
Is there a way to construct a 4 th equation which I'm missing?
Thanks!
Answers and Replies
Dick
26,263
620
The parameters a,b,c and d are not independent if you are given that it's a circle. Write the equation of a circle in the form (x-a)^2+(y-b)^2=r^2. Now you only have three parameters. And you have three points.
IniquiTrance
190
What if I used Gauss Jordan elimination to find a,b and c in terms of parameter d, would that sufficiently answer the question?
Dick
26,263
620
Sure, I suppose. The 'fourth parameter' is really that you can divide your whole equation by any one of the four parameters that is nonzero and eliminate it. It was never really there to begin with. I.e. x^2+y^2+bx+cy+d=0 is also just as good.
Suggested for: System of linear equations
  • Last Post
  • Last Post
  • Last Post
