Systems of linear equations
In summary, the first statement is true, as a homogeneous linear system with the same number of equations as unknowns always has a unique solution. For the second statement, it is false, as a linear system can have no solution even if the rank of the coefficient matrix is less than the number of equations. And for the third statement, it is true, as a linear system with the same number of equations as unknowns and an invertible coefficient matrix will have exactly one solution.
baher
1)Determine whether the given statement is true or false.
A homogeneous linear system with the same number of equations as unknowns always
2)Determine whether the given statement is true or false.
If a linear system has no solution, the rank of the coecient matrix must be less than
3)Determine whether the given statement is true or false.
If a linear system has the same number of equations as unknowns and the coecient
matrix is invertible, the system has exactly one solution.
My answers was true false true , is that right ? :D
Hey baher and welcome to the forums.
For these kind of questions, it helps the other readers and members here to understand what you are thinking and how you arrived at the particular answers you arrived at.
I will start by commenting on the first question.
Consider that you have a system with n-equations with n-unknowns. This is a square matrix. This means it has a determinant. What values does a determinant have? What happens when that determinant is 0?
1. What is a system of linear equations?
A system of linear equations is a set of two or more equations that contain two or more variables. The solution to a system of linear equations is a set of values for the variables that satisfies all of the equations in the system.
2. How do I solve a system of linear equations?
There are several methods for solving a system of linear equations, including graphing, substitution, and elimination. Each method involves manipulating the equations to eliminate one of the variables, and then solving for the remaining variables.
3. Can a system of linear equations have more than one solution?
Yes, a system of linear equations can have one, infinite, or no solutions. A system with one solution means the two lines intersect at one point, while a system with infinite solutions means the two lines are the same line. A system with no solutions means the two lines are parallel and do not intersect.
4. What is the importance of systems of linear equations?
Systems of linear equations are used in many fields, including mathematics, physics, engineering, and economics. They can be used to model and solve real-world problems, such as determining the optimal production levels for a company or finding the intersection point of two moving objects.
5. Are there any special cases or exceptions in solving systems of linear equations?
Yes, there are a few special cases to be aware of when solving systems of linear equations. These include systems with no solutions, infinite solutions, or inconsistent equations. Inconsistent equations are equations that contradict each other and have no solution. It is important to carefully analyze the equations and their properties in order to accurately solve a system of linear equations.
