Homework Help: T and mg in a pendulum system
  1. Sep 26, 2007 #1
    I'm having trouble with the idea of tension in a pendulum. I've reasoned out my answers, but they're wrong. Am I missing a concept completely or am I overlooking a detail?
    The following questions deal with a pendulum in motion with angle not being its extreme end where v = 0 m/s
    1. T is smallest when angle= ± angle not
    2. The vertical component of tension is constant.
    3. T = Mg at some angle between zero and angle not.
    4. T is greater than Mg when angle=angle not
    5. T is largest at the bottom (angle=0)
    6. T equals Mg when angle = angle not
    2. Relevant equations
    sum of vertical forces = 0
    T cos A = mg
    sum of horizontal forces = 0
    T sin A = F
    3. The attempt at a solution
    True No motion occurs at this point so no centripital acceleration occurs
    True vertical component of T is always constant, it is equal to mg horizontal force always vary according to the angle
    True at different points the system has the properties of T<mg and T>mg. You can obtain this change without passing through T=mg.
    False T will be less than the weight at the top of the swing, because there's no motion and hence no centripetal acceleration
    True The tension in a pendulum string will be greater than weight at the bottom of the swing, because it has to provide an upward net acceleration
    False T < mg at the apex of the pendulums motion
Draft saved Draft deleted
