1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Tagential hall's effect
  1. May 30, 2009 #1
    Hi everybody.. I have a question on tagential magnetic field.
    I have a ferromagnetic material in longitudinal magnetic field and i necessary to know the component tangential H (magnetizing force) of this field by probe hall effect in this material near at your inside surfice. If the probe hall value of Ht1 in air is correct to say Ht1 = Ht2 ? And if true what mathematical law is applied?
    Tanks and best regards
    • Ht.pdf
      File size:
      22.9 KB
  3. May 30, 2009 #2
    IF the H (and B) field is along z, and there is no surface current J at the boundary (in x-z plane or y-z plane) , then curl H = 0, so dHz/dx = -dHz/dy = 0.
    In your picture, Bz inside ferrite = u Bz outside ferrite, where u = relative permeability..
  4. May 30, 2009 #3
    If H is a static field, then H tangential is continuous, so you are right to say Ht1=Ht2.
    If H is oscillating in time, it is more complicated.
  5. May 30, 2009 #4
    Tanks.. Exuse me if i do not draw the cartesian axial. Hence Ht1 = Ht2 along x-axsis and y-axsis.
    If instead surface current J because the ferromagetic material is trought by current is not true Ht1 = Ht2 but I can say che H1 about Ht2?
  6. May 30, 2009 #5
    Yay, boundary conditions!
    Take a look starting at page 57: http://www.amanogawa.com/archive/docs/EM5.pdf
    Basically, for almost any real material the tangential magnetic field is continuous. If you have surface currents, then the difference in the tangential components will be related to the surface current density.
  7. May 31, 2009 #6
    Tanks for your replay... and exuse me if i do not write a english correct...
    Best regard
Similar Threads - Tagential hall's effect Date
I Hall Effect in an alternating current circuit Feb 12, 2018
B Difference between relative velocity and effective velocity Dec 28, 2017
I Hall effect Mar 3, 2017
I Hall Voltage vs Laplace Force Jul 20, 2016
Problem of formula Hall constant Sep 28, 2014
