Taking Pictures From Outer Space: Color or B&W?
  • Thread starter brianthewhitie7
  • Tags
    Pictures
In summary: The satellites orbiting Neptune have sensors that are sensitive to light at a particular color, but they aren't able to see colors very well. So, the pictures that come back are usually enhanced (brightened or darkened) to make them more visible. The satellites orbiting Neptune also have sensors that are sensitive to light at a particular color, but they aren't able to see colors very well. So, the pictures that come back are usually enhanced (brightened or darkened) to make them more visible.
brianthewhitie7
When satelites go to other planets to study them and take pictures are the pictures in color or black and white? and if they are in black in white how do they know what the color really is when adding color to the pictures?
Astronomy news on Phys.org
Satellites orbit a single body, like Earth; they don't go from one planet to another. Instead, call them 'probes' or simply ' spacecraft .'
They do indeed take color photographs. Often the colors are enhanced or modified before their publication, however. The sunlight is so dim at Neptune, for example, that it's unlikely than any human being there would be able detect any significant color with the eye, so it's meaningless to ask what the color there "really is."
- Warren
Well, I think it would be a little more precise to say that all digital photos are taken with monochrome sensors that one way or another are alternatly filtered to allow one color at a time to pass through. Some cameras take 3 (or 4, with a luminance image) separate photos, mechanically alternating colored filters. The photos are combined later into a single color photo. Other cameras have a matrix of colored filters attached to the sensor to alternate colors on one sensor. The software controlling the camera knows which pixels are which colors and assigns them accordingly. Obvously, this method reduces the effective resolution of the sensor. It's called a Bayer Matrix: http://www.cyanogen.com/help/maxdslr/One-Shot_Color_and_the_Bayer_Array.htm
I don't know for sure, but I would guess that, as warren implies, most space probes and telescopes have "color" sensors that use the Bayer matrix.
Most photos taken through most cameras require color calibration unless careful control of the lighting is available. For the Mars rovers, for example, color calibration is a major problem (it is the Red Planet...) and as such the rovers were sent up with a sundial with color calibration spots on it so that the colors can easily calibrated once the photos are sent to Earth.
http://marsrovers.nasa.gov/mission/ spacecraft _instru_calibr.html
It may be beyond the scope of what you were asking, but some pictures you see use "synthetic" color - the filters used to provide the color aren't actually full-color filters, but filters that only allow a very specific single frequency of light through, such as the hydrogen alpha emission line (a specific frequency of red). Here's one famous Hubble image and how it was taken: http://www.pbs.org/wgbh/nova/origins/hubble.html
And this was a lesson hard-learned. The pictures that came back from the earlier Mars landers were manually interpreted, and for years we thought that Mars had a blue sky like Earth. That's why they put the colour calibration on later landers.
If you read the press releases from NASA sites, like from the Cassini site, they mention at what wavelength the photo(s) was(were) taken and how they were modified to show details on the planet or its satellites. They also have a section where you can view the raw images, i.e. unprocessed versions.(at reduced size)
http://saturn.jpl.nasa.gov/home/index.cfm
1. Can color photos be taken from outer space?
Yes, color photos can be taken from outer space. In fact, most photos taken from outer space are in color. This is because satellites and telescopes use specialized cameras that are capable of capturing images in different wavelengths of light, including those that are visible to the human eye.
2. Are black and white photos better for capturing details in outer space?
It depends on the purpose of the photo. Black and white photos can be useful for highlighting specific details in an image, such as the contrast between light and dark areas. However, color photos can also provide important information about the composition and temperature of objects in outer space.
3. Do different colors represent different elements in outer space photos?
Yes, different colors can represent different elements in outer space photos. For example, in images taken by infrared cameras, red can represent cooler objects while blue can represent hotter objects. In photos taken by X-ray telescopes, different colors can represent different energies of X-rays emitted by celestial bodies.
4. How are colors added to photos taken in outer space?
Colors are added to photos taken in outer space through a process called color mapping. This involves assigning specific colors to different wavelengths of light captured by the camera. The resulting image is a combination of these colors, giving us a visually appealing representation of the object or area photographed.
5. Do astronauts use color or black and white cameras when taking photos in space?
Astronauts typically use both color and black and white cameras when taking photos in space. They may use color cameras to capture images of the Earth or other colorful objects, while black and white cameras may be used for scientific purposes, such as capturing images of stars or galaxies. Both types of cameras are important for documenting and studying our universe.
  • Astronomy and Astrophysics
  • General Discussion
