Check Value of Tan(A+B): 7/25, 5/13 - Acute & Obtuse
  • Thread starter lemon
In summary, the exact value of tan(A+B) when sinA=7/25 and sinB=5/13, with A being acute and B being obtuse, is -36/323 or approximately -0.1 (1 decimal place). Parentheses should be used to clarify the order of operations when solving the equation.
lemon
200
1. If sinA=7/25 and sinB=5/13, where A is acute and B is obtuse, find the exact value of tan(A+B)
2. Tan(A+B)=tanA+tanB/1-tanAtanB
3. TanA=7/24
TanB=5/-12
Tan(A+B)=7/24+5/-12/1-7/24x5/-12=-36/323 or -0.1 (1d.p.)
Could somebody please check this for me, please?
Hi lemon! :smile:
Very good :approve:, except :rolleyes:
read the question … it asks for the exact value, which I assume means leave it as a fraction (exactly as the original data were given). :wink:
Removed the extra bold tags...
Please use parentheses. You have everything jammed together, so it's difficult to tell what's in the numerator and what's in the denominator. This should be written as
tan(A + B) = (tan A + tan B)/(1 - tan A * tan B)
lemon said:
3. TanA=7/24
TanB=5/-12
Again, please use parentheses. It would be clearer as
tan(A + B) = (7/24 - 5/12)/(1 - (7/24)(-5/12))
Your answer of -36/323 [itex]\approx[/itex] -0.111455 [itex]\approx[/itex] -0.1 is correct.
Understood. Thanks to you both
What is the formula for finding the value of tan(A+B)?
The formula for finding the value of tan(A+B) is tan(A+B) = (tanA + tanB) / (1 - tanAtanB).
How do you determine if the given angles are acute or obtuse?
An acute angle is any angle that measures less than 90 degrees, while an obtuse angle measures more than 90 degrees. To determine if the given angles are acute or obtuse, we need to know the values of angles A and B.
What are the given values of angles A and B?
The given values of angles A and B are A = 7/25 and B = 5/13.
How do you calculate the value of tan(A+B) if the angles are acute?
If the angles A and B are acute, then the value of tan(A+B) can be calculated using the formula tan(A+B) = (tanA + tanB) / (1 - tanAtanB). Simply plug in the values of A and B to solve for the result.
How do you calculate the value of tan(A+B) if the angles are obtuse?
If the angles A and B are obtuse, then the value of tan(A+B) can still be calculated using the same formula: tan(A+B) = (tanA + tanB) / (1 - tanAtanB). However, since the angle is obtuse, the value of tanA and tanB will be negative. Be sure to include the negative sign in the calculation.
