Tangent bundle
  • Thread starter math6
The triplet \left ( TM,M,\pi \right ) is a vector bundle called the tangent bundle TM such that M is its manifold basis, \pi : TM \rightarrow M the canonical projection. \left ( x^{i},y^{i} \right ) is a local coordinate system on a map \left ( \pi^{-1}(U),\varphi_{U} \right ).
x^{i} is the system of map coordinates \left ( U,\varphi \right ) of M and y^{i} are as
y= y^{i}\frac{\partial }{\partial x^{i}} , y \in T_{x}M .
Now if we take a new system of coordinates \left ( \tilde{x}^{i}, \tilde{y}^{i} \right )
on a map ( \pi^{-1}(V),\phi _{U} \right ) . \tilde{x}^{i} is the system of map coordinates \left ( V,\psi \right ) of M.
Then after the change of coordinates we have the following results :
( 1) \frac{\partial }{\partial \tilde{x}^{i}} = \frac{\partial x^{k}}{\partial \tilde{x}^{i}}\frac{\partial }{\partial x^{k}} .
(2) \tilde{y}^{j}= \frac{\partial x^{j}}{\partial \tilde{x}^{l}}y^{l}.
My question is this: It is clear from (1) that {x}^{i} depends \tilde{x}^{j} (and vice versa)
also {y}^{i} depends \tilde{y}^{j}. So \tilde{y}^{j} does it depend of {x}^{i} ?
What is the value then of \frac{\partial \tilde{y}^{j}}{\partial x^{i}} ?
In short, I seek the independence of variables \left ( x^{i},y^{i} \right ) and \left ( \tilde{x}^{i}, \tilde{y}^{i} \right ).
Answers and Replies
Fredrik
Staff Emeritus
413
Please put itex or tex tags around the LaTeX expressions. Use the preview feature to verify that they images look the way you intended. You need to refresh and resend after each preview (due to a bug).
Yes, use the features. Now, the whole point is that coordinates [itex]x^i[/itex] in a natural way coordinates on the tangent bundle. And normally this is how the tangent bundle is described. I am not sure from your post whether [itex]y^i[/tex] are the induced coordinates in this way, or "any coordinates", for instance referring to some selected "moving frame".
The triplet [tex]\left ( TM,M,\pi \right )[/tex] is a vector bundle called the tangent bundle [tex]TM[/tex] such that [tex]M[/tex] is its manifold basis, [tex]\pi : TM \rightarrow M[/tex] the canonical projection. [tex]\left ( x^{i},y^{i} \right )[/tex] is a local coordinate system on a map [tex]\left ( \pi^{-1}(U),\varphi_{U} \right )[/tex].
[tex]x^{i}[/tex] is the system of map coordinates [tex]\left ( U,\varphi \right )[/tex] of [tex]M[/tex] and [tex]y^{i}[/tex] are as
[tex]y= y^{i}\frac{\partial }{\partial x^{i}} , y \in T_{x}M[/tex] .
Now if we take a new system of coordinates [tex]\left ( \tilde{x}^{i}, \tilde{y}^{i} \right )[/tex]
on a map [tex]( \pi^{-1}(V),\phi _{U} \right ),\tilde{x}^{i})[/tex] is the system of map coordinates [tex]\left ( V,\psi \right )[/tex] of [tex]M[/tex].
(1) [tex]\frac{\partial }{\partial \tilde{x}^{i}} = \frac{\partial x^{k}}{\partial \tilde{x}^{i}}\frac{\partial }{\partial x^{k}}[/tex] .
(2) [tex]\tilde{y}^{j}= \frac{\partial x^{j}}{\partial \tilde{x}^{l}}y^{l}[/tex].
My question is this: It is clear from (1) that [tex]{x}^{i}[/tex] depends [tex]\tilde{x}^{j}[/tex] (and vice versa)
also [tex]{y}^{i}[/tex] depends [tex]\tilde{y}^{j}[/tex] So [tex]\tilde{y}^{j}[/tex] does it depend of [tex]{x}^{i}[/tex] ?
What is the value then of [tex]\frac{\partial \tilde{y}^{j}}{\partial x^{i}}[/tex] ?
In short, I seek the independence of variables [tex]\left ( x^{i},y^{i} \right )[/tex] and [tex]\left ( \tilde{x}^{i}, \tilde{y}^{i} \right )[/tex]
Although I don't have an answer to your question, this might help you get more responses by those that are more knowledgeable.
Kevin
Related Threads on Tangent bundle
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
  • Last Post
