Tangent to a circle
  • Thread starter sooyong94
Given that the line ##y=mx+c## is a tangent to the circle ##(x-a)^{2} +(y-b)^{2} =r^{2}##, show that ##(1+m^{2}) r^{2}=(c-b+ma)^{2}##
Quadratic discriminant, sum and product of roots
I substituted y=mx+c into the equation of the circle, and this is what I have:
##(x-a)^{2} +(mx+c-b)^{2} =r^{2}##
Then I expanded and simplified into this:
##(1+m^{2})x^{2}+(2mc-2mb-2a)x+a^{2}+b^{2}-2bc+c^{2}-r^{2}=0##
Now if I have to use the quadratic discriminant it would be tedious to work with, unfortunately. :(
Answers and Replies
There's a lot of Algebraic manipulation in this problem.
First hint: Find m, which is the same as ##\frac{dy}{dx}##
Second hint: solve for c in terms of only a, b, x, y
Third hint: Show both sides of the equations are equal to each other (again, only in terms of a, b, x, y).
Edit: This is in the Precalculus section. Have you learned how to find ##\frac{dy}{dx}## yet?
utkarshakash
Use the concept that the radius of circle is equal to the distance of the given line from the centre of circle. You already know the formula for finding the distance of any point from a line and in this case it is simply the centre of circle (a,b). Equate both and you're done.
pasmith
2,113
738
You should have expanded only so far as
[tex]
(1 + m^2)x^2 + 2(m(c-b) - a)x + a^2 + (c-b)^2 - r^2 = 0
[/tex]
Keeping (c-b) as (c-b) throughout will make your calculations much less tedious.
Related Threads on Tangent to a circle
  • Last Post
  • Last Post
  • Last Post
  • Last Post
14K
  • Last Post
