How can I make a tautological conclusion from these premises?
  • Thread starter ETuten
In summary, the premises state that either cube A or cube B exists, and either dodec C or dodec D exists, and that either cube A or dodec C do not exist. The conclusion is that either cube B or dodec D exists. To make a tautological conclusion, you can use material conditional and destructive dilemma, or you can use the tautology (~P->Q)->(~R->S)->(P->R)->(~Q->~S). Both methods lead to the same conclusion.
ETuten
I am in needof help with the following problem:
Premises : Cube(a) v Cube(b)
Dodec(c) v Dodec(d)
~Cube(a) v ~Dodec(c)
Conclusion: Cube(b) v Dodec(d)
I need to add a sentence to the proof that is tautalogical consequence of two of the premises. I just can't see how to make such a deduction. Any help would be much appreciated
well it's quite immediate if take into account material conditional and destructive dillema:
~cube(a)->cube(b)
~dodec(c)->dodec(d)
so from DD you get the conclusion.
but let's say for the sake of argument that you can't use it here, so:
so what about ((Cube(a)vCube(b))->(Dodec(c)vDodec(d))->(~Cube(a)v~Dodec(c))->(Cube(b)vDodec(d))
you only need to check that then next thing is a tautology, quite long:
((~P->Q)->(~R->S)->(P->R)->(~Q->~S))
but as you might see it's all equivalent.
One way to make a tautological conclusion from these premises is by using the rule of disjunctive syllogism. This rule states that if we have two disjunctions (statements joined by "or") and the negation of one of the disjuncts, then we can conclude the other disjunct. In this case, we have the premises "Cube(a) v Cube(b)" and "~Cube(a) v ~Dodec(c)", and by applying the rule of disjunctive syllogism, we can conclude "Cube(b) v Dodec(c)". This is a tautological conclusion because it is always true, regardless of the truth values of the premises.
What is Tautological Consequence?
Tautological Consequence is a concept in logic that refers to the relationship between a set of premises and a conclusion, where the conclusion is necessarily true if the premises are true.
What is an example of Tautological Consequence?
An example of Tautological Consequence is the statement "All mammals have lungs" as a conclusion from the premises "All cats have lungs" and "All dogs have lungs".
How is Tautological Consequence different from Logical Consequence?
Tautological Consequence is a specific type of Logical Consequence, where the conclusion is always true based on the premises, while in Logical Consequence, the conclusion is only likely to be true based on the premises.
What are some common symbols used to represent Tautological Consequence?
The most common symbols used to represent Tautological Consequence are "⊨" and "⊢". These symbols are read as "entails" or "therefore" and indicate that the conclusion follows necessarily from the premises.
Why is Tautological Consequence important in scientific research?
Tautological Consequence is important in scientific research because it helps to ensure the validity and soundness of arguments. By understanding and utilizing this concept, scientists can make logical and valid conclusions from their data, leading to more accurate and reliable research results.
  • General Math
  • Electromagnetism
  • General Discussion
  • Topology and Analysis
