Homework Help: Taylor approximations
  1. Jul 10, 2009 #1
    1. Use Taylor's Theorem to determine the accuracy of the approximation.
    [tex] arcsin(0.4) = 0.4 + \frac{(0.4)^{3}}{2*3}}[/tex]
    2. Determine the degree of the Maclaurin polynomial required for the error in the approximation of the function at the indicated value fo x to be less than 0.0001. Use a symbolic differentiation utility to obtain and evaluate the required derivatives.
    [tex]f(x) = ln(x+1)[/tex] approximate f(1.5)
    2. Relevant equations
    3. The attempt at a solution
    1.
    [tex]f(x) = arcsin (0.4)[/tex]
    [tex] x = 0.4[/tex]
    [tex]a = 0.5[/tex]
    [tex]N = 3[/tex]
    [tex]R_{n}(x) = \frac{f^{N+1}(c)}{(N+1)!}(x-a)^{N+1}[/tex]
    [tex]R_{3}(0.4) = \frac{f^{4}(c)}{4!}(0.4-0.5)^{4}[/tex]
    [tex]= \frac{\frac{-3c(2c^{2}+3)}{(c^{2}-1)^{3}\sqrt{1-c^{2}}}}{4!}(0.4-0.5)^{4}[/tex] [tex]\leq[/tex] [tex]\frac{(0.4-0.5)^{4}}{4!} = 4.166666667 * 10^{-6}[/tex]
    Book Answer: [tex]R_{3} \leq 7.82 * 10^{-3}[/tex]
    No idea what I did wrong here.
    2.
    [tex]a = 0[/tex]
    [tex]x = 1.5[/tex]
    [tex]N = ?[/tex]
    [tex]R_{n}(x) = \frac{f^{N+1}(c)}{(N+1)!}(1.5)^{N+1}[/tex]
    [tex]|R_{n}(1.5)| \leq 0.0001[/tex]
    To make a long sheet of work short, I got all the way up to N=12 before I finally got to 0.0001. Here is the work for N=12:
    N=12: [tex]|R_{12}(1.5)| = |\frac{f^{13}(c)}{13!}(1.5)^{13}| = |\frac{(479001600)}{(c+1)^{13}} * \frac{(1.5)^{13}}{13!}| = |\frac{(479001600)(3.1254*10^{-8})}{(c+1)^{13}}| = \frac{14.9707}{(c+1)^{13}} [/tex]
    [tex]\frac{14.9707}{(1.5+1)^{13}} = 0.0001[/tex]
    The book answer says N=9, for which when I tested I got this:
    N=9: [tex]|R_{9}(1.5)| = |\frac{f^{10}(c)}{10!}(1.5)^{10}| = |\frac{(-362880)}{(c+1)^{10}} * \frac{(1.5)^{10}}{10!}| = |\frac{(-362880)(0.000106)}{(c+1)^{10}}| = \frac{5.7665}{(c+1)^{10}} [/tex]
    [tex]\frac{5.77665}{(1.5+1)^{10}} = 0.000605[/tex] which isn't exactly less than 0.001.
    When I went back through my notes to see if I did something wrong, I realized that since the function was decreasing, (c+1), on the bottom of the fraction, maybe I should have plugged in 0, since c should be greater than or equal to 0 and less than or equal to 1.5, thus the biggest R could be would be whatever I get when I plug 0 in, not 1.5.
    However, if I plug in 0 for these instead of 1.5, it seems to make the problem worse, since as you can see, N=9, with 0 instead of 1.5 for C would get 1 on the bottom and thus R_9 would be 5.77665, which is very very far from 0.0001, much farther than when I used 1.5.
    I'm thoroughly frustrated by this one. Please help!
  3. Jul 11, 2009 #2
    You chose a=0.5. Probably that is a good choice. But then what would be the Taylor series? Not the one shown. So the writers of the problem did not choose a=0.5. What did they choose? The point is that the Taylor series for their choice is much simpler to write down than for your choice a=0.5.
  4. Jul 12, 2009 #3
    I think they chose a=0? Is that right?
  5. Jul 12, 2009 #4
    a = 0 is the way to get that Taylor series, yes. So do the rest of the problem on that basis.
