Possible webpage title: Proving the Taylor Inequality for Positive Values of x
  • Thread starter transgalactic
  • Tags
    Taylor
In summary: At the level of answering Taylor Series questions, I don't think anyone would think twice about you simply stating that the inequality x > sin x, x>0 holds. Once you agree on that, one could integrate both sides of that inequality between 0 and some number, with gives us an inequality for cos in terms of t. Then integrate that one from 0 to x, you'll see where this is getting at.
transgalactic
1,395
prove this inequality for x>0
[tex]
x-\frac{x^3}{6}+\frac{x^5}{120}>\sin x
[/tex]
this is a tailor series for sin x
[tex]
sinx=x-\frac{x^3}{6}+\frac{x^5}{120}+R_5
[/tex]
for this innequality to be correct the remainder must be negative
but i can't prove it because there are values for c when the -sin c expression will be possitive
[tex]
R_5=\frac{-sin(c)}{6!}x^6
[/tex]
i got another approach
[tex]
f(x)=x-\frac{x^3}{6}+\frac{x^5}{120}-sin
[/tex]
[tex]
f'(x)=1-\frac{x^2}{2}x+\frac{x^4}{24}-\cos x
[/tex]
[tex]
f''(x)=-x+\frac{x^3}{6}+\sin x
[/tex]
[tex]
f^{(3)}(x)=-1+\frac{x^2}{2}+\cos x
[/tex]
[tex]
f^{(4)}(x)=x-\sin x
[/tex]
in this point how to know that the 4th derivative is always positive for x>0
[tex]
[/tex]
Yes, this is a Taylor's series, but more precisely it is a Maclaurin series since it is in powers of x or x - 0.
transgalactic said:
[tex]
[/tex]
[tex]
[/tex]
I seem to remember that you asked this same question before. How did it turn out that time?
The remainder formula gives bounds on c. What are they for your problem? Your problem also states what values of x to consider. Understanding the bounds on c and the possible values for x will help you with evaluating -sin(c).
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
[tex]
f^{(4)}(x)=x-\sin x
[/tex]
Did you look at what I wrote in my previous post?
you say that i should bound c
so the -sinc will give a ngative value
but i cent do it
i have x>0
and in this area it can be both possitive and negative .
i prefer to shoe that the 4th derivative is always positive for x>0
how to show that?
I don't understand what you're doing, but here's some help at what you're trying to do.
g(x) = x - sin(x) is 0 at x = 0, and g'(x) > 0 except at x = k*pi. That should tell you something about the sign of x - sin(x).
its not proving that the 4th derivative is positive
Really, at the level of answering Taylor Series questions I don't think anyone would think twice about you simply stating that the inequality x > sin x, x>0 holds.
what do you man that level
i can't just say that x>sinx
x>0
i need to base this fact on some math or whatever
What is Taylor's inequality proof?
Taylor's inequality proof is a mathematical proof that provides an upper bound for the error between a function and its Taylor polynomial approximation.
How is Taylor's inequality used?
Taylor's inequality is used to estimate the error in approximating a function with its Taylor polynomial. It helps to determine how close the approximation is to the actual function.
What are the assumptions of Taylor's inequality?
The assumptions of Taylor's inequality are that the function is continuous and has a finite number of derivatives within the interval of interest.
Can Taylor's inequality be applied to all functions?
No, Taylor's inequality can only be applied to smooth functions that satisfy the assumptions mentioned above.
What is the significance of Taylor's inequality?
Taylor's inequality is important in mathematics as it provides a way to accurately approximate a function using its Taylor polynomial, which can be very useful in many applications such as physics and engineering.
