Measure 2+ Signals at Once w/ Tektronix DPO4104
  • Thread starter Tsuriel Avraham
In summary, the oscilloscope can only trigger on one channel at a time. Meaning you can't measure two channels independently. Hence, if the two signals you are trying to measure have no relation to each other it is difficult to measure both. However, this is very rarely a problem if you are measuring on a single circuit.
Tsuriel Avraham
how do i measure two (or more...) signals at once?
i mean, when i try to measure two signals (with difrrent frequecies) with two difrrent probes, i get one good signal (almost clean...) and the other one, is look very dirty...
thank you!
I am not sure what you mean. The oscilloscope can only trigger on one channel at a time. meaning you can't measure two channels independently. Hence. if the two signals you are trying to measure have no relation to each other it is difficult to measure both (you might still be able to use the scope as a digitizer).
That said, this is very rarely a problem if you are measuring on a single circuit, unless of course you really have two signals with no fixed relationship?
i understand...
the two probes are not related (two difrent circuits...).
thank you :)
This seems to be a triggering problem (or feature).
The scope trigger determines when the machine starts to draw the line. There are a number of options depending on your scope. Most scopes have one trigger for all the channels (with several methods of selecting when it activates). Most people want to know what is happening on the various channels at the same time. This means two channels at random frequencies don't play well together. Yet it allows us to see if one frequency is synchronized with the other (perhaps at an harmonic).
Read up on triggering and triggering options. Your scope may or may not support a solution to this dual trigger problem. What make and model is your scope?
You can always plot (or take a picture) with the trigger on one channel, then switch the trigger to the other and do it again.
tektronix dpo 4104bl
Just use the "Single-Shot" trigger to capture both waveforms at once on the screen. You can then do all of your measurements on each waveform separately using the cursor measurement options. :smile:
thank you! :) :) :)
1. How many signals can the Tektronix DPO4104 measure at once?
The Tektronix DPO4104 can measure up to four signals simultaneously.
2. What types of signals can the Tektronix DPO4104 measure?
The Tektronix DPO4104 can measure a wide range of signals, including analog, digital, and mixed signals.
3. What is the bandwidth of the Tektronix DPO4104?
The Tektronix DPO4104 has a bandwidth of 1 GHz, making it suitable for a variety of applications.
4. Can the Tektronix DPO4104 capture signals in real-time?
Yes, the Tektronix DPO4104 has a real-time sampling rate of up to 5 GS/s, allowing for accurate and precise signal capture.
5. Is the Tektronix DPO4104 user-friendly?
Yes, the Tektronix DPO4104 has a user-friendly interface and can be easily operated by both experienced and novice users.
  • Electrical Engineering
12K
