Stargazing Telescope guiding techniques
  1. Oct 23, 2017 #41
    2017 Award
    Yes. That's what I meant. Identifying a player and following him is not as easy if there's just one led on him. The total player image is what your eye makes best use of. This is particularly relevant, of course, when the lighting is low (low SNR). This is precisely what the processing in my idea would do.
    I am disappointed that the reaction to this idea has been so negative. Stacking is just a way of using information gathered over an extended time. My idea is merely gathering more relevant information by looking over an extended spatial region; there is a direct correspondence. The process is not as obvious as the way a single star guider uses. The conventional guider can only work for a star that is bright enough for a simple algorithm to work. Is it not obvious that there is far more information available in the total field than in the position of just one star? You do not need to identify the positions of individual stars and work on each individually. It is the whole field that would be processed.
    Here's one method that would work. Take the 2D correlation function between successive captured frames. That will give a peak which corresponds to the displacement vector. For a totally random distribution there will be a single peak and there can be other subsidiary peaks where there are regular features in the sky but the sky has no repeating patterns so the correlation peak would be high. You can take frames at as high a rate as your correlation process time and camera noise will allow. Noise and hot cells would be addressed in the same way as normal imaging is treated.
  2. Oct 23, 2017 #42
    Staff Emeritus
    I actually disagree somewhat. A single LED per player would make identifying his position in low-light levels easy compared to having no LED on the player. But I can't see how this applies to autoguiding. All we're worried about is making sure our telescopes stay pointed at the same location in the sky where the objects are all moving at approximately the same rate. Having point-sources makes guiding extremely easy compared to trying to identify extended, diffuse sources. And since the stars are indeed the closest thing to a point source we can get, having even one of them gives you all of the pointing accuracy you will need.
    There may be a correspondence, but I don't agree that it is useful for autoguiding. Autoguiding takes place in an environment of very low signal, where you often cannot rely on finding more than one or two good sources to guide off of without increasing the exposure time for your guider to 20+ seconds, which is starting to be too long to effectively correct for mount errors. So unless you're pushing the limits of this timeframe, you're unlikely to be able to use more than one or two sources.
    I'm not following you. If you can't even see the stars because they're buried in the noise, how can you possibly use them for anything?
    Normal imaging addresses noise by increasing the exposure time or combining exposures to increase the SNR of the image. Neither of these are good options for an autoguider, as they both increase the time between mount corrections.
    My basic objection is that I don't see how your method is effective in the extremely low light levels associated with the night sky. As I've asked already, how can you use stars that you can't even see? You have no correlation if the noise is overwhelmingly dominant, and the only way to get the stars' signals out of the noise is to either increase the exposure time or combine images. Both of which are only useful if you can do so while keeping your mount corrections coming at intervals of at most 10-15 seconds, 15-20 if your mount is above average.
    Beyond that I still don't see how this is any more useful to astrophotographers than guiding with a single star. Accuracy certainly isn't increased since the autoguider itself is not the limiting factor, as we've explained earlier. And since that appears to be the main appeal of your method, I can't understand why you're still pushing it as a viable and useful method.
    Please note that I'm not saying your method flat out doesn't work. Of course it works. It's just that, in my opinion, there's nothing to be gained by using it. It's neither more accurate, less costly, or easier to use than guiding with a single star as far as I can tell.
  3. Oct 23, 2017 #43
    2017 Award
    which is great for imaging an object ... it works well
    But as Drakkith said, it's useless for guiding because of the time lag
    and as long as there is a star, you can guide on it
    what more relevant info ??
    again, the screenshot from the guiding software ......
    You can see multiple stars in that shot, you can select whichever one you like.
    It doesn't matter which one you select as they are all moving with the same motion(s).
    There are 3 motions....
    1) the natural motion across the sky
    2) motion that strays from that natural motion because of the mount polar alignment inaccuracies ( I have already mentioned this in a previous post)
    3) motion that strays from that natural motion because of the mount motor gear meshing inaccuracies ( I have already mentioned this in a previous post)
    Guiding, be it auto or manual, aims to remove the inaccuracies of #2 and #3 so as to get the scope tracking the natural motion of the guide star (and as a result, the object being imaged) as accurately as possible
    yet again, you don't need multiple stars when just one star provides the same amount of info, there is nothing to be gained by tracking multiple stars
    If there was, I'm sure they would be doing it already. Auto-guiding has been around long enough for that to be realised if it was of use.
  4. Oct 24, 2017 #44
    2017 Award
    Of course it is and I am not suggesting it as a method.
    I thought this made it clear. You have to think 'inside out' to get what I mean, perhaps but you must see that integrating over space and integrating over time will both improve results. Stacking is over time and this method is over space. It is particularly suitable for use with stars as they have identical profiles so the correlation peak would be very well defined.
    and yet again I say that it isn't "multiple stars"; it's just a whole image.
    That's reassuring. :smile:
    I get that. But you are hanging your argument on the present system.
    Which is precisely what the correlation method would do - images from all over a single exposure.
    Stacking achieves just that and so does the correlation method (in the spatial domain and not the time domain)
    Both processes aim to deliver as much of the incident light from a particular part of space as possible on one particular part of the sensor. How can you separate them in any discussion? The systematic deviations of pointing, due to the mechanics of the mount can be reduced more and more by increasing the SNR of the guide control loop because an 'intelligent' loop can learn and precorrect. Backlash is harder to deal with, of course. You have repeated that the present guiding system is good enough but is it? The earlier post about clockwork tracking being 'quite good enough' may be worth re reading.
    There a definitely two halves to this thread. The theory is something I feel confident about but, of course, present practice is not in my experience (yet). I totally accept how the present system is preferable because it is: 1. Easy to understand and explain: 2. available to buy. These make the choice pretty well a no brainer at the moment. But PF discusses many blue skies ideas and I hold that there are better guiding methods possible and probably on the horizon. (No puns intended here.)
  5. Oct 24, 2017 #45
    My name is Dr. Gaston Baudat from Innovations Foresight, the company which makes the ONAG.
    We are in the process of releaseing a new software for auto-guiding and real time auto-focus (focusing while the imager shutter is opened) using the all guider frame.
    This patent pending approach leverages the ONAG large guider FOV at once (APS-C size chips, up to 28mm in diagonal) and the ever lower cost CMOS cameras.
    With proper statistical processing one can extract image registration information for auto-guiding purpose even under SNR values down to 0dB.
    In this approach one does not need, nor look for a specific guide star(s), but instead for any astronomical structures (if fact it works with any image, not only astronomical ones).
    No assumption are made about the image, only about the noise floor for extracting the relevant information from the background.
    You can see a demonstration in The Astro-Imaging Channel (TAIC) presentation I gave few months back on this topic:
  6. Oct 24, 2017 #46
    2017 Award
    Well how about that? Thank you for that contribution. It does the sort of thing I was suggesting and you have filled in a valuable gap for me because you have actual hardware and figures. I can imagine everyone having one in the too distant future. :smile:
  7. Oct 24, 2017 #47
    The idea behind is if one can guide on axis (and with a wide FOV) you are likely to guide on/near the actual target of interest.
    Therefore by processing the whole guider (large diagonal guider chip) image we could extract registration (and rotational) information for auto-guiding, plus real time auto-focus information when using the astigmatism induced image on the guider side (no distortion on the imager side).
    Of course it is a matter of SNR, as usually, if too low, for a given guider exposure time, there maybe not enough signal to guide, but so does a guide star based approach.
    There is an old joke in signal processing community, "without any noise you do not need any signal".
    The good news is that you usually image a target therefore there should be some signal, hopefully.
    A key aspect here is to modelize the noise from a statistical stand point, not the actual mage content (like assuming any guide star(s)).
    In a nutshell the algorithm at work is based on optimal filtering theory and can do a pretty good job even under low SNR values, depending of the target and the noise level, but of course there is limit, like any other approaches.
  8. Oct 24, 2017 #48
    Staff Emeritus
    Then I am apparently entirely unfamiliar with spatial correlation techniques. Do you have any good links or references?
    Do you know the SNR limit for this technique compared to that of a normal guide star based approach?
  9. Oct 24, 2017 #49
    The noise modelization is the heart of the technique and related to Kalman filter theory, you can find more on this here:
    The image registration using spatial correlation is relatively straightforward when the first step mentioned above, extracting signal from the noise floor, has been achieved, Here is some basic math about digital image correlation:
    Some aspects, let say some tricks and details of the implementation, are company confidential information, therefore I cannot elaborate more on those (sorry).
    As far as comparison with other guide star centrodi based algorithms goes I could give rough numbers only, since it is a function of many parameters, such as how many guide star centroid are used in the same time (usually only one) .
    I have not done very extensive/comprehensive tests but I would say that with one guide star and a centroid strategy you many need around 6 to 10 db of SNR, while the full frame technique work with SNR around 0 dB or so.
    But this is not a totally fair comparison since the full frame technique uses all the image information at once (all the pixels), not any specific star (there is no need to locate/select any star manually or automatically).
    Of course there are provisions for removing hot pixels, artifacts, ...
    Basically each pixel is weighed against its level of information versus the noise floor (I should better say versus the noise model). A pixel with larger information content likelihood level contributes more in the registration calculation.
    In short all guiding camera pixels are part of the process but with various weights related to their level of credibility for the task.
  10. Oct 24, 2017 #50
    Staff Emeritus
    Thanks Gaston.
    My apologies to @sophiecentaur. I was ignorant of my ignorance when it comes to spatial correlation.
  11. Oct 25, 2017 #51
    2017 Award
    @Drakkith : Unknown unknowns?
    To be fair, I didn't explain it as well as Gaston did and he actually showed that it works. You would have needed to believe an old BS'er to take what I said as being gospel.
    :smile: Your problem now is that you WANT ONE!!
    Mr Shannon got it right all those years ago and he had virtually no hardware to test the idea.
  12. Oct 25, 2017 #52
    Staff: Mentor
    I'm locking this thread for being overly speculative and will likely (when I get a more time later) split it between two threads:
    1. A thread on real Telescope Autoguiding Techniques to help people improve their autoguiding (what the title of this thread implies it should be about).
    2. A thread on this new full-frame guiding idea proposed by @Gaston Baudat
    Please note:
    The provided materials on the full frame guiding method are dense, yet and a bit thin in details (explicitly saying they won't go into the details). However, it appears to say that the secret sauce is in the noise filtration technique, not in the multi-star guiding technique. The objections raised to the idea of multi-star guiding previously and the circularity of the argument still appear to apply (if you can't track one star then you can't track more than one star, but what if you can track more than one star...?, you can't track one star, so you can't track more than one star). Anyway, frankly, the quality of the noise filtering appears to me to be too good to be true.
    Multi-star guiding exists and has two advantages that don't apply to most people (which is why it isn't used much) or apply to the previous discussion:
    1. If seeing is really bad and you have several guide star candidates of similar SNR you could jump back and forth between them as the SNR goes from "not enough" to "enough" for individual stars in successive frames. This would be a rare situation and when seeing is that bad you probably don't want to be imaging anyway.
    2. It can allow you to correct for field rotation during imaging -- in only some cases and only if you have special equipment to rotate the camera while imaging. Field rotation is generally corrected after imaging, using a similar technique in software. It requires combining shorter exposure images.
Similar Threads - Telescope guiding techniques Date
Stargazing Where to buy telescope that measures spectrum? Feb 19, 2018
Stargazing Is this a good telescope? Jan 10, 2018
B The League of Extraordinarily BIG Telescopes Jan 2, 2018
Stargazing Radio Telescope Guide Jul 19, 2016
Stargazing Buying a Telescope , guide me. Feb 26, 2008
