Stargazing Telescope Staying Out
  • Thread starter Bob3141592
I have a C8 on a tripod that I don't use as much as I'd like. One thing is my proximity to Chicago (45 miles NW of the city - not quite far enough away). Also, as my yard is set up, it's a real pain to take it in and out of the house. I'm not ready to build a shed observatory around it, so I was wondering if it would be bad for the scope to leave it out all the time. Even just leaving the tripod out would be better, but the best would be to keep the whole setup out all the time. I saw a protective cover for about $150 that claims to do just what I want ( http://www.optcorp.com/productList.aspx?uid=&pg=0&kw=cover&st=2 [Broken] ). Does anyone here have any experience with such a thing? I'd hate to put my scope at risk of damage from condensation or anything else. Will this really do what I want? Are there any other alternatives people have used?
chroot
Staff Emeritus
34
I've never used such a product, but I'm pretty skeptical, honestly. I agree that moisture/condensation would be your biggest enemy. A decent cap on the exit aperture pretty much makes the inside of the instrument air-tight, but I've never seen a lens cap for the corrector plate that's really air-tight. The one that came with my C-11 is actually so loose that remarkably large spiders can get inside it! So obviously water vapor is going to condense inside there, and you're going to get dew and perhaps frost on your corrector plate nearly every night. I have no idea how frost affects the lens coatings, but I have to assume it can't be good. Maybe a few packets of the "DO NOT EAT" dessicant would help things a bit, but Chicago's a really wet place in the winter!
- Warren
russ_watters
Mentor
18,992
5,146
I'll leave mine out for a few days at a time, but won't leave it in the rain or if the weather is going to be drippy humid.
343
For me, i have a small telescope similar to the one on this http://shopping.discovery.com/product-59071.html" [Broken] hoping that it is the telescope you are talking about. I can see what your saying, yours weighs 67lbs. I could see how that would limit you from going outside all the time. I used to keep my telescope in its case all the time because it would take less space but i used to get lazy of taking it out puting it together and when i was done then take it apart and bla bla bla.... and my telescope only weighs around 10lbs:surprised !! Personally now i keep my telescope out of the case and already set up and i store it in my room so its easier. I don't know about the bag or about leaving your telescope outside but if i were you personally, i would just keep your telescope already setup near the door so whenever you want you can just grab it and go outside without setting up.
another option you could try is to get a smaller lighter telescope. I would recomend that you get one with out weights that balance it since obviously it add more weight and takes more time to set up. Think of it this way you think you have it bad with your telescope now??? Think how long it would take to get one of http://www.meade.com/maxmount/index.html" [Broken] suckers out and to your yard:rofl: !!
Hope what i said helps in some way
Chronos
738
Leaving your instrument outside will degrade all the components. The mounto will not suffer, but, the optical elements will suffer if left exposed to the elements.
230
Life should be so tough, eh?
The idea of a smaller scope might be an option. First I'll try leaving the tripod out and just moving the optical tube in and out. That wopn't be ideal but it will be a help.
Thanks to everyone for all the advice. I was hesitant but hopeful about the claims associated with the cover. Perhaps a more structural approach like a shed with a roll off roof would be a better solution in the future. But since a shed (or even a fancy observatory with a dome) isn't airtight, why isn't moisture a problem with those arrangements?
Related Threads for: Telescope Staying Out
9K
  • Last Post
  • Last Post
