imran
- 18
what is rest mass? why does a photon have rest mass zero? :uhh:
Rest mass is a fundamental property of matter and is defined as the mass of an object when it is at rest. It is also known as invariant mass, meaning it does not change with the object's velocity.
Rest mass is different from other forms of mass, such as relativistic mass, in that it is intrinsic to an object and does not change with its velocity. Relativistic mass, on the other hand, changes with an object's velocity and is dependent on the observer's frame of reference.
Rest mass is typically measured in kilograms (kg) or electron volts (eV). In the SI system, the unit for mass is kg, while in the field of particle physics, eV is often used to measure the rest mass of particles.
No, photons do not have rest mass. They are massless particles and travel at the speed of light. This is supported by the theory of relativity, which states that objects with mass cannot reach the speed of light.
The fact that photons have zero rest mass is significant because it allows them to travel at the speed of light. This allows them to have unique properties, such as being able to travel infinitely far without losing energy and having both wave-like and particle-like behavior.
