Temp of a Blackhole
  1. Oct 13, 2015 #1
    The problem is to calculate the temperature of a one solar mass black hole
    2. Relevant equations
    [tex] S = \frac{8\pi^2GM^2k}{hc} [/tex]
    [tex] E = Mc^2 [/tex]
    [tex] \frac{1}{T} = \frac{\partial S}{\partial U} [/tex]
    3. The attempt at a solution
    My first solution I pulled out an [tex] Mc^2 [/tex] Which left my equation looking like [tex] S = \frac{k8\pi^2GM} {hc}*U [/tex] and did the partial derivative with respect to U of the entropy equation. I found that I was off by a factor of two (I think, I don't for sure know the right answer but some friends got answers 1/2 as much as my answer).
    I think I know why and I just want to check out my reasoning. By only factoring out one U instead of U^2 I left an M in the equation. But M and U are intricately related right? So I must take out a U^2 in order to take out all of the M's in the original equation. It is only then that I get the correct result (That being 6.14 *10^-8 K, which I believe to be right but I'm also not entirely sure.)
    Does this sound like a reasonable conclusion as to why I'm probably wrong?
    Thank you for any help you can offer!
  3. Oct 14, 2015 #2
    You forgot that through ##E=Mc^2## you have to use that ##\frac{\partial M}{\partial U}## also contributes to the derivative.
    Then you get the right result.
    Another approach you can use is using the chain rule.
    Then you can write ##\frac{1}{T} = \frac{\partial S}{\partial U} = \frac{\partial S}{\partial M}\frac{\partial M}{\partial U}##.
    Usually I would go for this.
    In this case the relation between E and M is simple but for harder problems (in possibly other domains) the algebraic manipulations can get ugly real quick increasing the probabilities of mistakes.
  4. Oct 20, 2015 #3
    This is so late I know, but, THANK YOU!!
    I didn't quite get it at the time... I mean I knew of the chain rule, I just never really recognized when to use it until JUST now.
    I've been shredding through a lot of problems tonight remembering to keep this little mathematical tool in my pocket.
  5. Oct 21, 2015 #4
    Your welcome. It's useful to look back at old problems whenever you learn something new.
    This helps you selecting suitable tools further on.
Have something to add?
Draft saved Draft deleted
