Temperature at the junction of 2 wires
In summary, the thermal conductivity of copper is 4 times that of brass. When two rods of copper and brass with the same length and cross section are joined end to end, with the free end of copper at 0 degrees Celsius and the free end of brass at 100 degrees Celsius, the temperature at the junction is 20 degrees Celsius. This can be calculated using the formula for heat flow, where the thermal conductivity of brass is represented by k, the thermal conductivity of copper is represented by 4k, the area of the rods is represented by A, and the length of the rods is represented by l. The problem can also be solved using the analogy between thermal and electrical circuits, where the resistance ratio of the two materials is
Deebu R
67
The thermal conductivity of copper is 4 times that of brass.Two rods of copper and brass having same length and cross section are joined end to end. The free end of copper is at 0 degree C and the free end of brass is at 100 degree C. The temperature at the junction is?
I don't know what equation to use.
R= r l/A?
Or thermal conductance = kl/A where k is the thermal conductivity?
Or is it something else?
Hi,
do you have a relevant equation that links temperature (or temperature difference) and thermal conductivity ?
BvU said:
Hi,
Sorry but I got nothing. Any hint or clue to help?
BvU said:
Something like Fourier's law, perhaps ?
To be honest this is the first time I have heard about that law.
So I got like,
Q=-k (0-100)= 100k
Q=-4k(100-0)= -400k?
That wouldn't work: the junction temperature doesn't appear. But you are on the right track. Length and area should indeed divide out. With heat and temperature drop it's just like with current and voltage drop. Check the dimensions.
I think I got it ,
Thermal conductivity of brass=k
Thermal conductivityof copper=4k
Area of rods= A and length=l
Temperature of the junction = θ
Rate of flow of heat= KA(100-θ)/l = 4kA(0-θ)/l
(100-θ)=4(0-θ)
5θ=100
θ= 20° C.
Correct?
Yes. Make it a habit to add (and check) dimensions.
That works. You've reach the correct result.
Note that heat flow and the flow of electricity are analogous. In effect we can analyze a thermal "circuit" as we would an electric circuit: Temperature difference is analogous to potential difference, heat flow to current flow, thermal conductivity to electrical conductivity. In either domain conductance is the reciprocal of resistance.
In this problem the two rods are identical except for material so we can immediately conclude that the brass rod will have 4 times the thermal resistance as the copper rod. The thermal circuit is analogous to a potential divider:
And since in a potential divider it's the resistance ratio that's important:
and you can write:
##T_j = 100~C \cdot \frac{1}{1 + 4} = 20~C##
1. What is the temperature at the junction of 2 wires?
The temperature at the junction of 2 wires is the average of the temperatures of the individual wires at that point. This is because heat is transferred between the two wires, causing them to reach an equilibrium temperature.
2. How is the temperature at the junction of 2 wires affected by the material of the wires?
The temperature at the junction of 2 wires can be affected by the material of the wires. Different materials have different thermal conductivities, which can impact how quickly heat is transferred between the two wires. This can result in a difference in temperature at the junction.
3. Does the length of the wires affect the temperature at the junction?
Yes, the length of the wires can affect the temperature at the junction. Longer wires have a greater surface area, which can lead to more heat transfer between them. This can result in a difference in temperature at the junction compared to shorter wires.
4. Can the temperature at the junction of 2 wires be measured accurately?
Yes, the temperature at the junction of 2 wires can be measured accurately using a thermometer or a thermal imaging camera. However, it is important to ensure that the measurement is taken at the exact junction point, as small differences in location can lead to variations in temperature readings.
5. What factors can affect the temperature at the junction of 2 wires?
The temperature at the junction of 2 wires can be affected by factors such as the material, length, and diameter of the wires, as well as the amount of current flowing through them. Other external factors such as ambient temperature and air flow can also impact the temperature at the junction.
