Temperature change scales
  • Thread starter Miike012
Miike012
1,011
Answer is in document.
The problem does make sense to me because how can you compare three difference temperature scales, and this is why I am posting the problem to make sure I am correct.
Basically what I did was assumed that the numbers at the bottom corresponded to absolute zero for the given scale then I calculated the difference between the ranges of the scale.
If this is correct I believe a general statement can be made here. the boiling point and freezing point of all temperature scales are related assuming all temperature scales are callibrated equally.
Answers and Replies
DrClaude
Mentor
7,878
4,486
You made a mistake in part b.
Note that this problem is a special case as all three temperature scales have degrees of the same size, which is not the case for instance for the Celsius and Fahrenheit scales.
Miike012
1,011
The only thing that I can think of is creating three equation, one of temperature W, Temp X, and temp Y. Then relating Temp W to temp X and also relate Temp Y to temp X then compare the values.
Is there another way of doing this?
DrClaude
Mentor
7,878
4,486
What you can do is come up with equations that allow you to convert from one scale to another. Then, choose one scale as the reference, convert the values on the other scales to that scale, then compare.
In the case where all the scales have the same size of degrees, you can also calculate the difference with respect to a fixed point, as you did comparing to the freezing point. You simply made a mistake in calculating one of the values.
Miike012
1,011
oops. It should have been 50 - 0 and not 90 - 0. Once I make that correction then will I have the correct values to compare?
Miike012
1,011
so it should be 50x , 50y , 50w
DrClaude
Mentor
7,878
4,486
Suggested for: Temperature change scales
  • Last Post
  • Last Post
