Homework Help: Temperature & Heat
  1. Jul 6, 2008 #1
    A thermos contains 155 cm3 at 87 degrees C. To cool the coffee, you drop two 12.2-g ice cubes into the thermos. The ice cubes are initially at 0 degrees C and melt completely. What is the final temperature of the coffee in degrees Celsius? Treat the coffee as if it were water
    2. Relevant equations
    (m*Lf)ice= (c*m*Delta T)water
    3. The attempt at a solution
    (.0244)(33.5x10^4)= (4186)(155)(Tf-87.0)
    T f= 86.987 degrees C
  3. Jul 6, 2008 #2
    Hootenanny
    Staff Emeritus
    What happens to the water that results from the ice melting?
  4. Jul 6, 2008 #3
    When the ice melts, it cools the coffee so the overall temperature decreases.
  5. Jul 6, 2008 #4
    Hootenanny
    Staff Emeritus
    Correct. Does the temperature of the melted ice stay at 0oC or does it change?
  6. Jul 6, 2008 #5
    The ice gains heat and the coffee loses heat
  7. Jul 7, 2008 #6
    Hootenanny
    Staff Emeritus
    Correct, but you haven't taken this into account in your calculations have you? You need to take into account the temperature change of the ice-water after it has melted.
  8. Jul 28, 2008 #7
    i think after ice melt , temperature of water (for Ice melt) will up and water in thermos will drop
    SO
    (m*Lf)ice + (m*c*(Tf-0))ice = (c*m*Delta T)water
    (.0244)(33.5x10^4)+(.0244)(4186)(Tf-0)= (4186)(155)(87-Tf)
