Temperature in Vacuum: Is it Zero or Undefined?
In summary: However, in vacuum, there is no particles.Even in a vacuum there is the electromagnetic field. It is everywhere. It vibrates at different frequencies, some are visible light, some are warmth, some are too low-frequency and weak for us to feel with our senses.
ChloeYip
93
I have learned that temperature is defined as the vibration of particles.
In reality, no absolute vacuum can be done, so I can't find answer online.
Do you think the temperature (in Kelvin) is zero or undefined?
Thank you.
Science news on Phys.org
Light
Heat glow.
Corresponding to any temperature there is a thermal mix of frequencies or mix of energies which you get as a heat glow off the walls of the box that you have your vacuum in. The light (in the general sense of electromagnetic radiation) inside the otherwise empty box has a temperature
Thank you fo your answer.
What if technology get more advanced in the future and block all EM wave? Would there be still temperature?
p.s. I am just a high school student, can you please answer in a more simple way? Thanks.
The vacuum is the ground state of quantum field theory. For any quantum mechanical system the vacuum is the equilibrium state with temperature ##0## and all chemical potentials ##0##.
Are you familiar with the concepts of heat conduction, convection, and radiation?
"Observation indicates that in our universe the grand total vacuum energy is extremely small and quite possibly exactly zero. Many theorists suspect that the total vacuum energy is exactly zero."
http://www.scientificamerican.com/article/follow-up-what-is-the-zer/
Probably not quite, but really really,really close...there would still be gravitational waves which are many,many times weaker [and which I think have never actually been detected they are so weak...really difficult to measure so far] ...
It is not.
The precise definition of temperature is complicated. A vacuum still has a temperature, in the absence of an radiation the temperature is zero. Without matter but with a bit of radiation, like we have it in space far away from stars, the temperature is about 3 K, close to zero but not zero (and we can reach much lower temperatures on Earth).
1. What is temperature in vacuum?
The temperature in vacuum refers to the measurement of the average kinetic energy of particles in a vacuum, which is the absence of matter or particles.
2. Is temperature in vacuum zero?
In classical physics, the temperature in vacuum is assumed to be zero as there are no particles to measure. However, in quantum mechanics, the temperature in vacuum can have non-zero values due to the existence of virtual particles.
3. Why is temperature in vacuum considered undefined?
In quantum mechanics, the concept of temperature in vacuum is considered undefined because of the uncertainty principle, which states that it is impossible to know the exact values of certain pairs of physical properties at the same time. Therefore, the temperature in vacuum cannot be precisely measured or defined.
4. Can temperature exist in a perfect vacuum?
In classical physics, temperature cannot exist in a perfect vacuum as there are no particles to measure. However, in quantum mechanics, the concept of temperature can still be applied to a perfect vacuum due to the existence of virtual particles.
5. How does the temperature in vacuum affect particle behavior?
The temperature in vacuum does not have a direct effect on particle behavior, as there are no particles to measure. However, the concept of temperature in vacuum is used in quantum mechanics to describe the behavior of virtual particles and their interactions with the vacuum. This can have implications in various fields such as cosmology and quantum field theory.
13K
  • Thermodynamics
  • Thermodynamics
14K
  • Thermodynamics
  • Thermodynamics
