Temperature of ideal gas?
  • Thread starter Outrageous
Outrageous
374
When 2 ideal gas mix, there will be no temperature change. Is that because there will not be any chemical reaction occur, so no temperature change?
thank
Answers and Replies
Rap
814
thank
If they are at different temperatures when you mix them, and there is no chemical reaction, the temperature of the mixture will be different than the two temperatures they had before you mixed them. That temperature will be somewhere in between the two.
That means, if they are at the same temperature when you mix them, and there is no chemical reaction, the final temperature will be the same as the initial temperatures.
There may or may not be a chemical reaction. If there is a chemical reaction, then figuring the final temperature is more complicated.
This all assumes that the volume of the mixture is the sum of the original volumes and that no heating or cooling is done from the outside and they don't do any work on each other or the outside and no particles are gained from or lost to the outside.
Outrageous
374
That means, if they are at the same temperature when you mix them, and there is no chemical reaction, the final temperature will be the same as the initial temperatures..
Exactly what I want to ask . Thank you
Suggested for: Temperature of ideal gas?
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
