Homework Help: Tension and waves help
  1. Nov 13, 2007 #1
    sun
    A circus performer stretches a tightrope between two towers. He strikes one end of the rope and sends a wave along it toward the other tower. He notes that it takes the wave 0.880 s to reach the opposite tower, 20.0 m away. If a 1 meter length of the rope has a mass of 0.255 kg, find the tension in the tightrope.
    2. Relevant equations
    v-f(lambda)
    v=sqrt.(tension/mu)
    mu=mass per unit length
    tension=mg
    f=1/t
    3. The attempt at a solution
    I solved for wave speed using v=f(lambda)
    f=1/T=1/.88s=1.136Hz
    Delta(x)=lambda=20m, so 20m x 1.136=22.72m/s
    Tension=v^2(mu) = (22.72)^2(.225/20) or (22.72)^2(.225/1) ??
    I'm not sure what i'm doing wrong. Suggestions would be appreciated.
    thanks
  3. Nov 13, 2007 #2
    Doc Al
    Staff: Mentor
    I'm not following all that calculation. You are not given any data about f, T, or lambda.
    The speed can be found simply by v = d/t = 20/.88 = 22.72m/s.
    .225 kg is the mass of a 1 m section; so mu = mass/length = .225 kg/m.
  4. Nov 13, 2007 #3
    sun
    i don't know what i'm doing wrong when i use 22.72 to calculate the tension in the rope using: v=sqrt.(tension/mu)
    maybe i'm calculating mu incorrectly? any ideas?
    thank you very much
  5. Nov 13, 2007 #4
    Doc Al
    Staff: Mentor
    You used two versions of mu. One is right; one is wrong.
  6. Nov 13, 2007 #5
    sun
    from what i've read i believe mu=.225 is the correct one. Because that is the mass for every 1 meter of string. Regardless of the mu i've been using i still get an incorrect answer.
    this is why i'm still a bit confused.
    thank you
  7. Nov 13, 2007 #6
    sun
    suggestions as to what i may be doing wrong would be greatly appreciated.
  8. Nov 13, 2007 #7
    sun
    i get 116.15N when i solve for tension, but this is wrong.
    I could really use some help as soon as possible, please.
    thank you
  9. Nov 14, 2007 #8
    Doc Al
    Staff: Mentor
    typo!
    Here's the likely problem: In your first post you state the mass as 0.255 kg, but in later posts you use 0.225 kg. Recalculate the answer using the correct value.
  10. Nov 14, 2007 #9
    sun
    Pure Genius!! :P
    At the rate i was going, i definitely would not have noticed that. :(
    thank you
Loading...
