Tension forces problems
I don't know why your 3:06 PM post is exactly the same as your 2:46 PM post.In summary, the conversation is about a physics problem involving tensions and pulleys. The problem involves a picture hanging on a wall suspended by two strings at different angles. The goal is to calculate the tension in the second string and the weight of the picture. The conversation includes multiple attempts at solving the problem, with some confusion and mistakes along the way. Eventually, the correct solution is reached by summing up the X and Y components of the forces and using trigonometry to solve for the tension and weight.
lurch0038
I am having difficulty with tensions and pulleys. Can someone give a good explanation of how they work and what are some rules to solve the problems I have for homework. As far as I can see, the book and the instructor is not that good in describing this topic
Here is one example of a problem:
A picture hangs on the wall suspended by two strings as seen in the figure 6-20(see below for a written explanation). The tension in string one is 1.7N. (a) is the tension in string 2 greater than, less than or equal to 1.7N (explain) (b)verify your answer by calculating the tension on in string 2 (c) what is the weight of the picture?
In the example there is a pictrue hanging in the middle of two strings, one string string one in 65degrees above the -X axis and string 2 is 32degrees above the X axis.
Here is what I have done:
T1x = 1.7(-cos115degrees)
T1y = 1.7(sin115 degrees)
and that is it...HELP!
More information...from what I am seeing
Sum of Fx=t1(-cos115) + T2(cos32)
Sum of Fy= t1(sin115) +T2(sin32) -mg + Normalforce.
This seems that theses are the sum of the forces acting on the picture hanging on the wall, is this correct?
How do I solve for the tension on the second string T2 if I do not have any information such as the wieght of the picture, or the force of T2??
Thanks in advance
I think I have a clue as to solve this problem.
Since the forces acting on the picture =0 (because it is at rest) I can set the Sum of the Y forces equal to 0 and the sum of the Xforces equal to 0...like below
sum Fx = T1(-cos115) + T2(cos32)
1.7(-.422) + T2(.848)
0 = -.717 + T2(.848) (solve for T2)
.717 = T2(.848)
T2 = .845 (not rounding up)
Once I know T2 I can get the X and Y components of the tension T2
T2x = .845(cos32) =.716
T2y = .845(sin32) = .447 (not rounding up)
Sum of Fy = T1(sin115) +T2(sin32) -mg + Normal force
0 = 1.7(.906) + .845(.529) -m(9.81) + N
0 = 1.54 + .447 -m(9.81) + N
I got this far so how do I solve for the normal force and the weight of the picture??
thanks in advance...
it gets even better!
I assume that there is no normal force because it is hanging, is that correct?
so all I need to do is sum up the Y forces and solve for the mass...
sumFy = T1y(sin115) + T2y(sin32) -mg
0 = 1.7(.906) + .849(.529) -m(9.81)
0 = 1.54 + .449 -m(9.81) (solve for m)
0 = 1.99 -m(9.81)
-1.99 = -m(9.81)
m = .202
Weight of picture is :
.202(9.81) = 1.99
Sound correct??
I bow to the physics gods!
Glad we could help.
I blew this one!the .848 is the force of the X component of T2.
so for me to get the Y component of F2 I need to do...
Tan32 = h/b
tan32 = H/.848
.624 = H/.848
.624(.848) = h
.529 = h = the Y component of T2
Need to recalculate the rest of the problem...
T2^2 = .848^2 + .529^2
T2^2 = .719 + .279
T2^2 = .998
T2 = .998 ?
Sorry for the long post !
When i get the information out of the problem Physics is cool!
No. You were right the first time. You're just getting confused by the rounding and the similarity between the value of cos32 and the magnitude of t2.
Without rounding, you would do:
t2 = 1.7*cos65/cos32
and therefore the weight is give by
mg = (1.7*cos65/cos32)*sin32 + 1.7*sin65
mg = 1.99 N
PS: .848 is not the x-component of t2.
t2 = 1.7*cos65/cos32 = .847 N
That is the full magnitude of t2. The x-component is .847*cos32 = .718 N
Ok let me get this straight...and I felt good that I was able to work this through.
By summing up all of the X components T2x, T1x, Nx, MGx I get the equation
T2x = T2(cos32)
T1x = 1.7(cos115)
Nx = 0 (no X movement for the normal force)
mgx = 0 (weight is only in the Y direction)
SumFx = 0 (net force = 0 due to no motion F=m(0) = 0 )
sumFx = T2x(cos32) + 1.7(cos115) + 0 + 0
0 = T2x(.848) + 1.7(-.042) + 0 + 0
0 = T2x(.848) + (-.0714)
.714 = T2x(.848)
T2x =.842 (may be off by a smidge due to rounding up)
then I would take the T2x and using the angle of the T2 I can solve for the T2y and then eventually T2...correct??
tan32 = T2y/.842
.624 = T2y/.842
T2y = .624(.842)
T2y = .526
T2^2 = T2x^2 +T2y^2
T2^2 = .848^2 + .624^2
T2^2 = .719 + .389
T2^2 = 1.038
T2 = 1.018 (a little different from the first calc due to rounding and maybe a mistake but is the format to solve this correct??
Thanks
sorry about that, I only posted it once but somehow it posted twice...very odd?
NO!
T2x = T2(cos32)
T1x = 1.7(cos115)
Nx = 0 (no X movement for the normal force)Forget about normal force. It has no relevance to this problem, so just leave it out.
In the following 5 lines, the red x doesn't belong there.
0 = T2x(.848) + 1.7(-.042) That should be 1.7(-.4226)
0 = T2x(.848) + (-.0714) Should be (-.718)
.714 {should be .718} = T2x(.848)
T2 = .847 Note: NOT T2x
You may be confusing x:multiplication operator with x:subscript.
Then, everything from that point on that is based on tan32 is wrong.
As I said before, the solution you posted at 2:46 PM was correct, except for minor rounding errors (and the fact that you did some extra work in converting force to mass & then converting back to force) which actually netted out to the correct result anyway.
I am sorry but as you can see I am a rookie at physics :(
I guess I don't quite understand why the X component of T2 is the vector T2 (the tension on the second string)?
Like I said I am a rookie at this but how can you solve for T2 without getting an X and Y component? My line of thinking was that if I solved string 2 X component (by summing all of the X components of both strings) I could then solve for the magnitude of the tension on the second string T2.
I know that there is some super reason why you are right but is it possible to explain why?
Thanks for your guidance.
I don't understand what happened. You had the right answer, but then around 3:00 you started thinking your way up a dead end.
T1 is a vector directed up & to the left. T1*cos115 is its x component. T1*sin115 is its y component.
T2 is a vector directed up & to the right. T2*cos32 is its x component. T2*sin32 is its y component.
w is a vector directed straight down. (w = -mg)
So the equation in the x-direction is:
T1*cos115 + T2*cos32 = 0
The equation in the y-direction is:
T1*sin115 + T2*sin32 + w = 0
That's all there is in this problem.
You seemed to understand this when you set up the equations initially. Then it seems you got mixed up when you put in numbers.
When you solve the first equation, you should get T2 = .84718
That is the FULL MAGNITUDE OF T2, NOT the x-component of T2. Do you see that? (The x-component of T2 is .84718*cos32=.71845) OK?
I see now! I am solving for T2 which is T2 and the X component of T2 would be T2(cos32).
Thanks for the help!
Now I need to work on those damn pulley problems and the centrepial force problems...
1. What are tension forces?
Tension forces are forces that act on a body in opposite directions, pulling it apart. They arise when an object is stretched or pulled, and are often represented by arrows in diagrams.
2. How do you calculate tension forces?
Tension forces can be calculated using the equation F = T1 + T2 + T3 + ..., where F is the total force applied to the body and T1, T2, T3, etc. are the individual tension forces acting on the body.
3. What factors affect tension forces?
The magnitude of tension forces is affected by the mass of the object, the angle and direction of the applied force, and the strength and elasticity of the material the object is made of.
4. How do tension forces affect the stability of a structure?
Tension forces can cause structures to deform or even collapse if they exceed the strength of the materials used. However, they can also help distribute weight and provide stability in some cases.
5. Are tension forces always equal to each other?
In general, tension forces are not always equal to each other. However, in some cases, such as a rope being pulled by two people with equal force in opposite directions, the tension forces may be equal.
Suggested for: Tension forces problems
