Exploring the Mechanics of San Francisco Cable Cars
In summary, the cable cars in San Francisco are powered by an underground cable that moves at 9.5 mph and is controlled by large motors at a central power station. The cable stretches up to 100 ft during its lifetime and is kept at a constant tension by a "tensioning pulley." The pulley is attached to a 2000 kg block suspended in a deep hole by a rope and pulley system.
splac6996
37
The cable cars in San Francisco are pulled along their tracks by an underground steel cable that moves along at 9.5 mph. The cable is driven by large motors at a central power station and extends, via an intricate pulley arrangement, for several miles beneath the city streets. The length of a cable stretches by up to 100 ft during its lifetime. To keep the tension constant, the cable passes around a 1.5-m-diameter "tensioning pulley" that rolls back and forth on rails, as shown in the figure. A 2000 kg block is attached to the tensioning pulley's cart, via a rope and pulley, and is suspended in a deep hole.
  • 8.14.doc
Is there a question?
I find the mechanics of San Francisco's cable cars to be fascinating. The use of an underground steel cable to pull the cars along their tracks at a speed of 9.5 mph is a clever and efficient design. The fact that the cable is driven by large motors at a central power station and extends for several miles beneath the city streets highlights the intricacy of the system.
One interesting aspect of this system is the stretching of the cable by up to 100 ft during its lifetime. This suggests that the cable is under a significant amount of tension, and it is impressive that the tension is kept constant through the use of a 1.5-m-diameter tensioning pulley. This pulley, which rolls back and forth on rails, is a key component in maintaining the proper tension in the cable.
The use of a 2000 kg block attached to the tensioning pulley's cart, via a rope and pulley, is a brilliant solution to suspending the pulley in a deep hole. This allows for the tension to be adjusted as needed while also providing stability to the pulley.
Overall, the mechanics of San Francisco's cable cars demonstrate the ingenuity and precision of engineering in creating a reliable and efficient transportation system. It is clear that a lot of thought and planning went into the design and maintenance of these iconic cable cars.
1. What makes San Francisco cable cars unique?
San Francisco cable cars are unique because they are the only manually operated cable car system in the world. Unlike other forms of public transportation, the cable cars are powered by a moving underground cable, which is controlled by the grip operator on the car.
2. How do the cable cars work?
The cable cars work by gripping onto a moving cable that runs continuously under the street. This cable is powered by a large steam-powered engine at the cable car barn. The grip operator controls the speed and direction of the car by releasing or gripping the cable.
3. How long have cable cars been in operation in San Francisco?
Cable cars have been in operation in San Francisco since 1873. They were first developed to help transport people up and down the steep hills of the city, and have since become a beloved symbol of San Francisco.
4. How many cable cars are in operation in San Francisco?
Currently, there are 3 cable car lines in operation in San Francisco, with a total of 40 cars. Each line runs on a different route and has its own unique history and charm.
5. Are there any safety concerns with riding on a cable car?
Cable cars are considered a very safe form of transportation. However, it is important to hold onto the handrails while riding and to be aware of your surroundings. It is also recommended to avoid standing on the outside running boards of the car, as this can be dangerous.
15K
24K
  • General Discussion
