Tension in a string
physics kiddy
135
I have attached a pic with my question. I want to know if T1>T2 or not.
As much as I know, Tension in a string = Earth's Gravitational force. But this question is quite confusing.
Answers and Replies
shanykool
T=2m1m2g
(m1+m2)
shanykool
t2 would be greater if the mass in t2 is greater than the mass in t1
Doc Al
Mentor
45,433
1,882
Is the pulley massless and frictionless? That's the key.
Careful! That's not true. In general you'll have to solve for the tension in the string by applying Newton's 2nd law.
physics kiddy
135
T1 has a mass greater than T2.
Doc Al
Mentor
45,433
1,882
I don't know what you mean. T1 and T2 are tensions. Regardless of the size of the mass on the ends of the string segment, the tension on both sides of a massless and frictionless pulley will be the same.
Since the mass on each side of the pulley is the same (2m on each side, added up), it turns out that in this particular case the tension T1 = T2 = 2mg. (The masses don't accelerate.)
technician
1,506
Agree completely with DocAl and will add that the tension in a string is the same everywher.... all the way along it.
There is no resultant force on this system so it is either at rest or moving with constant velocity (speed) in one direction or the other.
The only string with a different tension is between the 2 masses m and m ...the tension in here will be mg
The tensions T1 and T2 will be 2mg
briantaekim
I personally think that T2 was meant for the second string connecting the masses on the right side of the pulley. Because usually the pulley doesn't have mass (for beginner class) and the tension is uniform in one continuous string (and this is assumed rather than stated). So... I worked out the problem w these assumptions below. Check it out. So the solution looks like T1>T2.
  • Tension in a string.pdf
cupid.callin
1,137
Only if the string is also of negligible mass :biggrin:
And if the pulley has some mass, you can find its moment of inertia and apply the equations of torque:
[itex]T_1 R - T_2 R = I\alpha = \frac{Ia}{R}[/itex]
Here I is moment of inertia of pulley and R is its radius ...
And if pulley has no mass, I=0 ...
physics kiddy
135
I apologize for confusing you all. I am sorry. I have cleared my doubts with the question. The question was that there's a pulley and two masses 2m and m are tied to the opposite ends of the pulley as shown in the figure. The tension between 2m and pulley is T1 and between m and pulley is T2. Is the tension T1>T2?
The pulley and string are assumed to be massless and frictionless.
Doc Al
Mentor
45,433
1,882
Are you sure that T2 refers to the tension between m and the pulley and not between m and m?
(Is this your diagram, or the one given with the problem?)
physics kiddy
135
Yes, I am sure.
Doc Al
Mentor
45,433
1,882
Yes, I am sure.
In that case, your question has already been answered.
physics kiddy
135
I can't figure out where the answer is. Please explain it once again. Thanks
Doc Al
Mentor
45,433
1,882
See post #6.
Suggested for: Tension in a string
  • Last Post
  • Last Post
  • Last Post
