Tension in String Homework: 300g Disk at 10ms^2
In summary, the tension in the string is just 300g\cdot10ms^{-2} and the net force on the disk is mg. If there is no friction, the acceleration of the disc would be g.
arpon
235
[/B]
A string is wound around a uniform disk of radius ##10cm## and mass ##300g##. The
disk is released from rest when the string is vertical and its top end is tied to a
fixed bar. Determine the tension in the string. [ ##g = 10 ms^{-2} ##]
I think it is just ##300g \cdot 10 ms^{-2}## ;
If so, what is the net vertical force on the disk? What acceleration would result?
The accelaration of the disc is ##g## .
But, the disc will rotate, I think. And there should be a torque. I shown in the picture, the tension of the string ## T## will create the torque.
arpon said:
The accelaration of the disc is gg .
The acceleration of the disk would be g if you took the string away. If there's any tension in the string the acceleration must be less.
Write the ##\Sigma F = ma## equation for the vertical direction.
I shown in the picture, there is tension in the string, but the net force in the vertical direction is still ##mg## .
OK, I see where you are confused. There are different ways of treating how the portion of the string wrapped around the disk comes into it.
The least confusing is to assume it barely wraps around at all, i.e. as though it is attached to the disk at the point where they meet.
If you want to consider a longer wrap, it gets complicated because the least friction will soon result in its being effectively attached. If we say there's no friction at all then you have to follow it around to where it is ultimately attached, at some arbitrary point on the rim. T will apply tangentially there, but nowhere else. At all other parts of the string touching the disk, the force exerted by the string is radial. We can go down that path if you like, or you can trust me that it will all come out the same in the end... as though the string is attached to the disk at the point where they first meet.
But why?
arpon said:
But why?
If there's no friction how can the string apply a tangential force all along its length? It has no grip. Can you open a screw-top jar with greasy hands?
I got your point. So, in this problem, the tension is simply 0.
I suggest you follow the standard procedure and draw a correct free body diagram of the disk instead of the diagram you drew. Are you familiar with the concept of a free body diagram?
Yes.
I think it will be as I drawn below:
And, ##F_{net} = ma## ; where, ##a## is the accelaration of the disc.
Will it be, ##a = g## ?
And I think there will be a torque acting on the disc, which is equal to ##Tr## ; where ##r## is the radius of the disc.
Again, torque = ##I \alpha## ; where, ##I## is moment of inertia and ##\alpha## is the angular accelaration;
So, ##Tr = \frac{1}{2} mr^2 \alpha##; because, moment of inertia of a disc with radius ##r##, is ##\frac {1}{2}mr^2##
##\alpha = \frac {2T}{mr}##
Again, ##a = r \alpha##
##a = r \frac {2T}{mr}##
##a = \frac {2T}{m} ##
And so,
##mg - T = ma = m \frac{2T}{m}##
##mg -T = 2T##
##T = \frac{1}{3} mg##
And so,
##mg -T = 2T##
That looks correct.:)
1. What is tension in a string?
Tension in a string is the amount of force that is being applied to the string in order to keep it taut or stretched. It is a measure of how much the string is being pulled in opposite directions.
2. How is tension calculated in a string?
Tension in a string can be calculated using the formula T=mg, where T is tension, m is the mass of the object attached to the string, and g is the acceleration due to gravity. In this case, the mass is 300g and the acceleration is 10ms^2, so the tension would be 300g*10ms^2 = 3000mN.
3. What factors can affect tension in a string?
There are several factors that can affect tension in a string, including the mass of the object attached to the string, the acceleration due to gravity, the length and thickness of the string, and any external forces acting on the string.
4. How does tension in a string change with different accelerations?
Tension in a string is directly proportional to acceleration, meaning that as acceleration increases, so does tension. In other words, the higher the acceleration, the more force is being applied to the string to keep it taut.
5. How does the mass of an object affect tension in a string?
The mass of an object attached to a string will directly affect the tension in the string. The higher the mass, the more force is needed to keep the string taut, resulting in a higher tension. This is why the formula for tension includes the mass of the object.
