Tension in a Uniform Cable: Where Does the Force Balance?
In summary, a uniform cable of weight w is hanging vertically downwards, with an upward force of magnitude w being exerted at its top end to balance the downward force of gravity. The tension in the cable at its top end is w, at its bottom end is also w, and at its middle is w/2. A graph of tension versus distance from the top end would be a straight line with a slope of -1.
Amar.alchemy
79
A uniform cable of weight w hangs vertically downward,supported by an upward force of magnitude w at its top end. What is the tension in the cable (a) at its top end; (b) at its bottom end; (c) at its middle? Your answer to each part must include a free-
body diagram. (Hint: For each question choose the body to analyze
to be a section of the cable or a point along the cable.) (d) Graph
the tension in the rope versus the distance from its top end.
Newtons first law since the body is not accelerating.
Actually i am not able to understand the problem itself. Particularly i am not able to understand the sentence "supported by an upward force of magnitude w at its top end" in the above problem statement. Kindly explain me??
I think it means what it says. Gravity exerts a downward force w on the cable and there is a balancing upward force w exerted at the top of the cable. So the cable is not accelerating since the net force on the cable is zero.
The phrase "supported by an upward force of magnitude w" is redundant. The rope is hanging and gravity exerts a downwards force w on it, so the pivot the rope hangs from must exert an upwards force w to prevent acceleration.
Hint for this problem: use the "black box" method. Once you choose a section of the rope to analyze, consider only the external forces acting on it; forget about the tension within the section.
Thanks Dick and ideasrule :-)
So it means, the force exerted by the pivot is equal to its weight.
What is tension in a uniform cable?
Tension in a uniform cable refers to the amount of force applied to the cable, which causes it to stretch or elongate. It is typically measured in units of Newtons or pounds.
Why is tension important in a uniform cable?
Tension is important in a uniform cable because it affects the overall strength and stability of the cable. The higher the tension, the more weight or force the cable can support without breaking or deforming.
How is tension calculated in a uniform cable?
Tension in a uniform cable is calculated using the formula T = F * L, where T is the tension, F is the force applied to the cable, and L is the length of the cable. This formula assumes that the cable is perfectly uniform and has no external forces acting on it.
What factors can affect tension in a uniform cable?
The tension in a uniform cable can be affected by various factors such as the weight of the object being supported by the cable, the length and thickness of the cable, and external forces such as wind or vibrations. Additionally, the material and condition of the cable can also impact tension.
How can tension in a uniform cable be controlled?
Tension in a uniform cable can be controlled by adjusting the amount of force applied to the cable, changing the length or thickness of the cable, or adding additional supports or reinforcements. It is important to carefully calculate and monitor tension in order to ensure the safety and stability of the cable.
