Homework Help: Tension on blocks on ramp
  1. Feb 28, 2016 #1
    The ramp in figure is frictionless. If the blocks are released from rest, which way does the 10 kg block side and what is the magnitude of its acceleration? θ=40°
    https://s.yimg.com/hd/answers/i/b94e08c806334d908a6afee7b8761bbd_A.png?a=answers&mr=0&x=1456730351&s=946fcf963764a48cb25be59052f47790 [Broken]
    2. Relevant equations
    3. The attempt at a solution
    m1=10kg, m2= 5kg
    For m1:
    ΣFx=m1a1
    T-m1gsinθ
    For m2
    ΣFx=m2a2
    I'm unsure how to proceed from here. Other online solutions seem to assume that a1=a2, is that true? Why/why not? Please help me in how to continue. Thanks!
  3. Feb 28, 2016 #2
    Provided the string is in-extensible, as can be assumed here, a1 must equal a2.
    The letters in bold should provide a clue to the reasoning behind this.
    Hope this helps,
    Qwertywerty.
  4. Feb 28, 2016 #3
    Given that fact, how should I proceed?
  5. Feb 28, 2016 #4
    You have two unknowns - Tension and acceleration(Tension is same throughout the string).
    You need two equations - Write Newton's law for both masses, and solve the two equations to obtain a.
  6. Feb 29, 2016 #5
    I tried to write out the equations as follows:
    m1ax=T - m1gsinθ
    m2ax=T - m2g
    Is this correct? Upon solving this I got an answer that is different than the one in the book
  7. Feb 29, 2016 #6
    Edit : Keep in mind, the directions of both accelerations. We have already arrived at a conclusion regarding the accelerations. What is that?
  8. Feb 29, 2016 #7
    I'm not sure what you mean by this. For m1, I have defined positive x to be up and parallel to the ramp. For m2, positive x is directly up.
  9. Feb 29, 2016 #8
    If one block goes up, the other one goes...Where?
  10. Feb 29, 2016 #9
    If one block goes up, the other goes down, I suppose. But how do I quantitate that idea?
  11. Feb 29, 2016 #10
    See above please
  12. Feb 29, 2016 #11
    For one block, acceleration would be in the direction of tension; in the other, not. You have to thus be careful while applying Newton's law.
  13. Feb 29, 2016 #12
    Could you please write out the correct force equations that I should use to solve for tension and acceleration?
  14. Feb 29, 2016 #13
    I'd rather you tried it for yourself.
    Assume that the 10kg mass goes up and the 5kg one down. Try the equations again.
    P.S - I have noted that you had made an attempt in post #5, but I'd like for you, to give it another go.
  15. Feb 29, 2016 #14
    Here's another attempt, which yielded the right answer.
    For m1:
    m1ax=T-m1gsinθ
    For m2:
    m2(-ax)=T-m2g
    m1ax+m1gsinθ=m2(-ax)+m2g
    ax(m1+m2)=m2g-m1gsinθ
    ax=(m2g-m1gsinθ)/(m1+m2)=(5*9.8-10*9.8*.64)/15=-0.92
  16. Feb 29, 2016 #15
    That seems to be correct. Congrats!
Have something to add?
Draft saved Draft deleted
Loading...
