Homework Help: Tension on cables ? Please help?
  1. Jan 13, 2013 #1
    What's the tension on each cable ? and the power required to overcome tension (?)
    Here's the diagram:
    http://en.wikipedia.org/wiki/File:Planincline-schema.JPG
    2. Relevant equations
    F=Vsin(theta) ( constant velocity ) = a= 0
    Inclined (24.25 degrees) to the horizontal plane)
    Weight of block: 25T lighter then the counterweight when pushed upwards.
    and 25T heavier when pushed downwards the inclined plane.
    Ascending and descending journey time: 4 min
    vertical height: 55m
    Average velocity calculated:
    Inclined displacement = 55M/ sin(24.25)
    Average velocity= (55m/sin(24.25))/2(60)s = 1.11 m/s on each journey upwards and downwards. ( is this right ? ) should it be divided by 4(60) instead?
    3. The attempt at a solution
    F(push) = (25 x 10^3)(9.81)sin(24.25)
    F(counterweight) = (50 x 10^3)(9.81)sin(24.25)
    Tension on cables: ((50 x 10^3)(9.81)sin(24.25)) - (25 x 10^3)(9.81)sin(24.25)
    The block is attached to the counterweight by two groups of 14 cables
    so is the tension on each group of cable = T= Total tension/2 = 50.350KN
    The power required to lift the block on each group of cable
    Work done = Tension x displacement
    Work done= 50.350 KN x 134m
    Work done= 6747.0 KN.m
    Work = 6747.0 KN.m/2(60) = 56.2 KW for each group of 14 cables.
    is this calculations correct ?
  3. Jan 15, 2013 #2
    "so is the tension on each group of cable = T= Total tension/2 = 50.350KN "
    What do you think? Can you compare this with anything else you know, in order to verify its rough value?
    You could ask/answer the same question in relation to power. What does 56 kW "look like"? Can you compare it with anything else you know, such as a car, a horse, or a kettle, say?
