Homework Help: Tension problem
  1. Sep 25, 2008 #1
    A truck is towing a 1.00*10^3 kg car at a constant speed up a hill that makes an angle of 5degrees with respect to the horizontal. A rope (negligable) is attached to the truck at an angle of 10 degrees with respect to the horizontal. Neglect friction. What is the tension in the rope?
    I'm not sure if the sum of the x and y components should be zero or not?
  3. Sep 25, 2008 #2
    tiny-tim
    Welcome to PF!
    Hi milo7979! Welcome to PF! :smile:
    Constant speed means zero acceleration …
    so, yes, the sum of the components in any direction must be zero. :smile:
    (though you might find it easier to use components along the slope :wink:)
  4. Sep 25, 2008 #3
    i thought about using different coordinates, but only one of the forces will be on the axis because there are three forces with different angles with respect to the horizontal. I can't seem to get all of the y components to equal zero. The y component of the normal force I assume is the same magnitude as the weight (1.0*10^3 * g= 9.8*10^3N), but there is still a y component to the Force from the truck. W and y component of N equal zero, so what am I missing?
  5. Sep 25, 2008 #4
    tiny-tim
    Yes, there are three forces, and two of them are along the slope and perpendicular to it … :wink:
  6. Sep 25, 2008 #5
    I don't think that two of the forces are along the x and y axis. N is perpendicular to the hill which is 5 degrees to the left of vertical, W which is straight down the vertical and F of truck pulling the car is 10 degrees above horizontal.
  7. Sep 26, 2008 #6
    tiny-tim
    oh, sorry :redface:
    I misread it …
    ok, the force you want is the tension in the rope, so calulate the normal force, and then take components of everything along the line of the rope. :smile:
