Tension problem!
  • Thread starter pkossak
pkossak
52
I really could use help on this one! I got this one wrong on the last test, it was driving me crazy. Spent almost half the time trying to figure it out.
Two wires support a beam of length L=16. A box hangs from a wire which is connected a distance of 12 m from the left edge of the beam. The tension in the left support wire is 500 N and the tension in the right support wire is 600 N. What is the mass of the box? DATA: acceleration of gravity=9.80 m/s2
My next test is today, thank you incredibly much if you can help me figure out what I was doing wrong here.
Answers and Replies
Doc Al
Mentor
45,447
1,907
Tell us what you did. (Are you given the mass of the beam? Is it uniform? Are the support wires vertical?)
pkossak
52
Not given the mass of the beam, yes the support wires are vertical.
The figure can be seen here http://www.msu.edu/~kossakze/physics.gif
The way I approached it was to consider the middle of the beam at m = 0. The left wire is at 8 m and 8 m*500 N + 4 m*x N (weight of box) = 8 m*600 N
nevermind.....wow.....got the answer, guess I didn't do that on the test.
Thanks anyway
Doc Al
Mentor
45,447
1,907
Good. As long as the wires are vertical and beam is uniform, no problem. Just set up your equations for equilibrium.
Suggested for: Tension problem!
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
