Tensor and Tensor Products
  • Thread starter Hluf
Dear All,
I need some explanations of properties of tensor and the tensor product on different states;
σ1ijσij2=_____________
Thank you.
Answers and Replies
ChrisVer
462
A tensor is a mathematical/geometrical object which has certain transformation properties under change of coordinates.
http://en.wikipedia.org/wiki/Tensor
You can have a tensor of rank n covariant and rank m contravariant
and a tensor of rank l covariant and rank k contravariant
Then their product will be a rank (n+l) covariant and (m+k) contravariant.
[itex] T^{i_{1}i_{2}...i_{m}}_{j_{1}j_{2}...j_{n}} T^{r_{1}r_{2}...r_{k}}_{w_{1}w_{2}...w_{l}}= R^{i_{1}i_{2}...i_{m}r_{1}r_{2}...r_{k}}_{j_{1}j_{2}...j_{n}w_{1}w_{2}...w_{l}}[/itex]
If you are talking about the tensor product for example between two matrices, the idea is almost the same...
In that case you define:
for [itex] A \in K^{p \times q} [/itex] and [itex] B \in K^{r \times s} [/itex]
[itex] A \times B \in K^{pr \times qs}[/itex]
So a matrix let's say 3x2 multiplied by tensor product with another 4x5 will give as a result a matrix 12x10.
in element notation, the product is defined as:
[itex] ( A \times B)_{(ik)(jl)}= A_{ij}B_{kl}[/itex]
or in matrix form you write for EACH element the matrix B and multiply it in the first line with A[11], A[12],...,A[1q]
the second line A[21],...A[2q] etc... (see attachment)
So if what you ask for are the pauli matrices [itex]\sigma^{1,2}[/itex] then the result will be a 4x4 matrix, with upper left 2x2 block the [itex]\sigma_{11}^{1} \sigma^{2}[/itex], the upper right 2x2 block [itex]\sigma_{12}^{1} \sigma^{2}[/itex], the lower left 2x2 block [itex]\sigma_{21}^{1} \sigma^{2}[/itex], and the lower right 2x2 block [itex]\sigma_{22}^{1} \sigma^{2}[/itex].
In this case though [itex]\sigma^{1}[/itex] has zero diagonal elements, so the upper left and lower right 2x2 blocks are zero, the other off diagonal blocks are the [itex]\sigma^{2}[/itex] matrices. If i did it correctly...
Related Threads on Tensor and Tensor Products
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
