Termal voltage question
  • Thread starter sp1974
sp1974
I have another homework problem involving termal voltage that I am stuck on since an Ampere wasn't given any help?
A battery whose emf is 3.0 V. and whose internal resistance is 0.70 ohms is connected to a circuit whose net resistance is 14.7 ohms. What is the terminal voltage of the battery?
Answers and Replies
cepheid
Staff Emeritus
38
It's true, the current was not given to you, because you can calculate the current in this circuit using Ohm's law. That is the whole point of the question.
sp1974
Yeah but dont you use intermal resistance * ampere to figure a number for voltage and than take that and subtract from emf to figure terminal voltage?
cepheid
Staff Emeritus
38
First of all, it's not "ampere." The name of the physical quantity you are measuring is 'current.' An 'ampere' is the name of the unit by which current is measured. What you are saying is an equivalent mistake to saying that force = "kilogram" * acceleration. Try not to confuse the names of quantities in physics with the names of the units used to measure those quantities.
Secondly, it is true that the voltage across the internal resistor will be the current through it multiplied by its resistance. The point I was trying to make was that it's okay that you haven't been given this current, because you can use Ohm's law for the whole circuit in order to calculate what the current is. (Hint: you have two resistors in series).
sp1974
So 3.0V = I(R1 + R2)
3V = I (15.4) and than solve for I which would be .1948A?
cepheid
Staff Emeritus
38
Yeah, that's right.
sp1974
But the question is asking for terminal voltage of the battery and this is in Ampere not volts.
cepheid
Staff Emeritus
38
Yeah, but now that you have the current, you can do what you yourself suggested in post #3 in order to find the voltage across the internal resistor. It was a two-step problem. Do you understand? You needed to find the current through the circuit in order to find the voltage drop across the internal resistor.
sp1974
sweet! 2.86V thanks!
Suggested for: Termal voltage question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
