KaranND
- 1
hey,everyone,could you please explain to me the terms Terminal Velocity and Drag in detail,as my exams are coming up.
Terminal velocity is the maximum speed an object can reach when falling through a fluid, such as air or water. It occurs when the force of gravity pulling the object down is balanced by the drag force pushing against it.
An object's mass does not directly affect its terminal velocity. However, a larger mass will require a greater amount of drag force to balance the force of gravity, so it may take longer for a heavier object to reach its terminal velocity.
The two main factors that affect an object's terminal velocity are its mass and its surface area. Objects with larger masses and smaller surface areas will reach a higher terminal velocity, while objects with smaller masses and larger surface areas will reach a lower terminal velocity.
Air resistance, also known as drag, is caused by the collision and friction between the air molecules and the surface of an object moving through the air. This creates a force that opposes the motion of the object and slows it down.
No, an object cannot have a terminal velocity in a vacuum because there is no air or other fluid to create a drag force. Without a drag force, the object will continue to accelerate due to the force of gravity until it reaches a speed limited only by the strength of its materials.
