Terminal Velocity of rain drops
In summary: But at a certain point, the air resistance becomes equal to the weight of the rain drop, and the raindrop's acceleration ceases. At this point, the raindrop has reached its terminal velocity, and will continue to fall at this speed until it reaches the ground.
jishitha
23
Please, explain the concept of terminal velocity on the help of rain drops... Is there is any retardation when rain falling to the ground.?
Yes, raindrops have a terminal velocity.
The weight of a raindrop scales with the volume of a raindrop -- the cube of its size. The air resistance of a raindrop scales roughly with the area of a raindrop -- the square of its size. If you assume that air resistance also scales with the square of velocity, this gives a relationship.
air resistance = gravity
v2r2 = k r3
v2 = k r3 / r2
v = √(kr)
where r is the raindrop radius, v is the fall rate and k is a constant of proportionality that includes the density of water, and acceleration of gravity and the viscosity of air.
So the fall rate will be smaller for smaller raindrops. If the raindrop size is very small, you get fog.
Rain drop having free fall. Am I right..? That is it get accelarated. Means, velocity changing... But. Terminal velocity is a constat velocity. Then how it happens..?
In short without math...
The rain drop falls because of gravity,they get accelerated towards Earth ground at 9.8 m/s^2 and this acceleration is constant,but their are also many other forces acting upon the rain drop which resist the accelerating motion of the rain drop ,one of them is air resistance ,air resistance apply an opposing force or a force opposite in direction of that of acceleration due to gravity i.e.. its force is upwards on the rain drop .When these two forces ,acceleration due to gravity and force due to air resistance becomes equal on the rain drop the rain drop stops accelerating any further and achieves a constant velocity known as terminal velocity.
For example one of your friend is pulling you on the left side with a certain force,you will be start moving towards left as he is pulling but then another friend of your's comes and from the same side he pushes you towards right with the same amount of force that the other friend is trying to pull you,what will happen you will stop moving because two equal in magnitude but opposing forces cancels each other.
Why they are pulling you and pushing you I have no idea...
Yes
Good Luck
The force caused by air resistance is proportional to its velocity. The higher the speed, the more force you need, why? because it is "moving" more air, and that is energy. How the surface is two dimensional and motion is exerted perpendicularly to the amount of air moved or impacted drop is measurable volume per unit second. The energy required to move the particles within this volume (subsequently dispersed by butterfly effect in contact with adjacent surfaces) comes from the kinetic energy, ie, its velocity, which in turn comes from the gravitational potential energy (as that advances in the gravitational force field is gaining speed at a rate of g, for the small scales can be considered constant, but you should realize that a field is ALWAYS unchanged "small" which is their difference, these are practical considerations, more than theoretical). The higher the speed, the volume of molecules per second and higher colliding energy transfer due to their impact and friction layers. The impact between the surface and the air is much more complicated than a simple impact because they involve different particles in motion, but you can get an idea intuitively. Since energy can neither be created nor destroyed, it just flows. On one side we gain speed thanks to the potential energy of gravity, but this gain is constant and on the other side have a loss because the consequences of interacting with other particles and dissipate energy, which is proportional to speed. As you can see the speed plays the role of intermediary in the process, and there is an equilibrium in which a special rate equals this "transfer" of energy, which is the terminal velocity. At this speed the energy dissipated is equal to the energy supplied by the gravitational field and hence remains constant.
Sorry for my English, I'm Spanish and I'm not very good with languages.
I imagine retardation to mean the object is slowing down.
The rain drops do not slow down, they merely cease speeding up, when they reach terminal velocity.
When objects fall near the Earth Surface, they have an initial acceleration of 9.8 ms-2, since gravity supplies the only Force acting on the drop - the weight of the rain drop.
As soon as the drop begins to fall, some air resistance develops, reducing the effect of the weight of the rain drop, and reducing its acceleration from 9.8 ms-2.
Air resistance has a higher value for an object moving at higher speeds, so eventually the rain drop will reach a speed where the size of air resistance exactly matches the weight force of the rain drop. At that time there will be no unbalanced Force acting on the drop, so it ceases to accelerate. It doesn't slow down, it just doesn't speed up; it has reached terminal velocity.
Air resistance.
Zz.
Thank you all...:-)
The force caused by air resistance is given by the equation D=kv where D is the drag force, v is the speed at which the drop is falling, and k is the proportionality constant between them.
The force of gravity is given by W=mg where W is the force caused by gravity, m is the object's mass, and g is the acceleration due to gravity, approx. 9.8 m/s^2.
Terminal velocity happens when D and W cancel each other out i.e. when they are equal. This happens when kv=mg or v=mg/k.
The big kicker about terminal velocity, though, is that it is never actually reached: only approached because as you approach terminal velocity, you accelerate less quickly.
1. What is terminal velocity?
Terminal velocity is the maximum velocity at which an object falls through a fluid, such as air or water. It occurs when the force of gravity is balanced by the resistance of the fluid, resulting in a constant velocity.
2. How does air resistance affect the terminal velocity of rain drops?
Air resistance, also known as drag force, plays a significant role in determining the terminal velocity of rain drops. As a rain drop falls through the air, it experiences a force in the opposite direction of its motion due to air resistance. This force increases as the velocity of the rain drop increases, until it reaches a point where it is equal to the force of gravity, resulting in a constant terminal velocity.
3. What factors affect the terminal velocity of rain drops?
The terminal velocity of rain drops is influenced by several factors, including the size and shape of the rain drop, the density and viscosity of the fluid it is falling through, and the effects of turbulence and wind. Additionally, the presence of impurities or pollutants in the fluid can also affect the terminal velocity.
4. How is the terminal velocity of rain drops calculated?
The terminal velocity of rain drops can be calculated using the drag equation, which takes into account the density and viscosity of the fluid, the cross-sectional area and shape of the rain drop, and the velocity of the drop. However, due to the complex nature of fluid dynamics, the calculation may not always accurately reflect the actual terminal velocity of a rain drop.
5. Does the terminal velocity of rain drops vary in different locations?
Yes, the terminal velocity of rain drops can vary depending on the location. Factors such as altitude, temperature, and humidity can affect the density and viscosity of the air, which in turn can impact the terminal velocity of rain drops. Additionally, the presence of wind or other atmospheric conditions can also affect the terminal velocity of rain drops in different locations.
  • Mechanics
16K
21K
  • Mechanics
