Tesla Coil Help
aabceh
Hello all,
I am in the process of building a tesla coil and I need a little help.
I have everything completed enough that I can start testing it. I plug the coil in and the spark gap fires immediately and continuously, but no arcs come out the toroid.
I tried moving the toroid closer to the secondary coil and putting a piece of wire sticking out of the toroid, but there are still no arcs.
If anyone has any suggestions, they would be greatly appreciated.
Answers and Replies
RaulTheUCSCSlug
25
Do the turns match for both coils? Couldn't it be a problem of the frequencies not matching up? Or maybe you have a weak transformer? Where do you test your tesla coil? In a garage or something?
aabceh
I have been testing it outside because I am using chicken wire as a ground. What do you mean about the turns matching up? Does the secondary need to have a multiple of the primary's coils? In my research I have never read anything about that, but I might just be missing it.
RaulTheUCSCSlug
25
I remember reading about how the secondary and primary coils have to match in frequency. Meaning if one coil has a certain amount of turns, then the other must have a certain amount of turns to match the frequency. I know these tesla coils can be quiet tricky. (Had a mate of mine that did one for a science fair project a couple years ago, and the first one they made was a failure.)
RaulTheUCSCSlug
25
I found that there was the term called "tuning" the coils, but can't really find anything beyond that.
aabceh
What I have found about tuning the coil is that you adjust the amount of turns in the primary to get the greatest output from the secondary, but everything I've found about it has said to try one position and measure the arc length, then try a different position and so on, but that doesn't really work when there are no sparks at all.
RaulTheUCSCSlug
25
Then there is something either wrong with your capacitor, or transformer. Or you may have a short some where in your circuit?
Suggested for: Tesla Coil Help
  • Last Post
  • Last Post
  • Last Post
