Develop Water Pressure Powered Motor | Tesla, Terry, Vane or Pelton
In summary, there is a need for developing a water pressure powered motor that can operate at .5 hr / 375 watt with approximately 1000 rpm and withstand a water temperature of 180 f / 82 c and a water flow rate of 20 GPM / 75 LPM. The best way to find direction for this project is to search for terms such as water turbine design and water turbine design calculations. There are many helpful resources available online, including a good overview of different types of water turbines for different flow rates and heads. The type of turbine needed will depend on the specific flow rate and pressure of the water. This is not a simple question with a quick solution, so expect to spend some time researching and designing the
Always why
Hi I need to develop a water pressure powered motor. .5 hr / 375 watt at aprox. 1000 rpm.
The water temp would be at 180 f / 82 c .
The water flow 20 GPM / 75 LPM
Can please get direction on the best type. Tesla, Terry , vane or Pelton .
This is my first post, i appreciate the help thank you
Good search terms are water turbine design and water turbine design calculations. The first set of search terms resulted in some excellent sites to get a good overview. One of the first hits from the second set of search terms is a very good summary of how to design several different types of water turbines for different flow rates and heads.
Your water flow rate and pressure will tell you what type of turbine is best. Expect to put some time into this, it is not a question with a quick simple easy answer.
Hi Thank you for your professional reply , i am not expecting an easy solution thank you.the direction , i am new to this net thing.
Likes jim hardy, berkeman and jrmichler
1. How does a water pressure powered motor work?
A water pressure powered motor works by utilizing the force of water to rotate a turbine or wheel, which then generates mechanical energy that can be converted into electricity. This is achieved through the use of a nozzle or jet that directs the flow of water onto the turbine blades, causing them to spin and produce power.
2. What is the difference between a Tesla, Terry, Vane, and Pelton water pressure powered motor?
These are all different types of water pressure powered motors that use different designs and mechanisms to harness the energy of water. A Tesla motor uses a series of rotating discs to create a vortex that drives the turbine, while a Terry motor uses a series of blades to capture the energy of the water. A Vane motor uses a set of curved blades to redirect the flow of water onto the turbine, and a Pelton motor uses a series of cups or buckets to catch the water and turn the turbine.
3. What are the advantages of using a water pressure powered motor?
One of the main advantages of using a water pressure powered motor is that it is a renewable and sustainable source of energy. Unlike fossil fuels, water is constantly replenished through the water cycle, making it an environmentally friendly option. Additionally, water pressure powered motors can be used in remote or off-grid locations, making them a reliable source of energy in areas without access to traditional power sources.
4. Are there any limitations or drawbacks to using a water pressure powered motor?
One limitation of water pressure powered motors is that they require a constant source of water to operate effectively. This means that they may not be suitable for areas with droughts or inconsistent water flow. Additionally, the initial cost of installing a water pressure powered motor can be high, although the long-term savings on energy costs can offset this.
5. How can a water pressure powered motor be used in practical applications?
A water pressure powered motor can be used in a variety of practical applications, such as generating electricity for homes, powering irrigation systems, or driving machinery in industries such as agriculture and manufacturing. They can also be used in combination with other renewable energy sources, such as solar or wind power, to create a more reliable and sustainable energy system.
  • Mechanical Engineering
  • DIY Projects
  • General Engineering
21K
