TeX on Webpage
  1. Dec 28, 2005 #1
    -Job-
    How do thse forums implement the TeX functionality? Did it come with the vBulletin software or is it separate? I want to get a TeX tool on my server but i haven't alot of experience with it. I assume that, in these forums, there is a compiler for TeX which is called by a PHP script producing images which are then linked to the respective posts. Is this the case or is there an actual PHP based TeX compiler script?
  3. Dec 29, 2005 #2
    -Job-
    After alot of searching and experimenting i ended up downloading MikTeX (for windows), from www.miktex.com. Compiling is a as simple as:
    latex -job-name=<output file's name> <input file's name> -output-directory=<out put directory>
    So now i should be able to call this from a PHP or ASP.NET script and i'll be all set. :smile:
    Except of course that it outputs as a .dvi file, and i want an image, but i'll get around it.
  4. Dec 29, 2005 #3
    -Job-
    Yes, there is a dvipng tool which builds a png image from the dvi file. It comes with MikTex, so no extra files to install, you call it with:
    dvipng <path to input dvi file> -o <path to output file>
    So it's a two step process, but it's doable. How cool.
  5. Dec 29, 2005 #4
    -Job-
    Yes, it's working!
  6. Dec 30, 2005 #5
    James R
    Seems you solved your own problem.
  7. Dec 30, 2005 #6
    -Job-
    I'm still curious how these boards implement it. I think there must be an easier way. For those who are curious, this is what i have:
    http://www.bloo.us/tex/services/previewer.aspx [Broken]
    It works with the Latex found in posts throughout these forums. I'm thinking of doing a full LaTex editor this coming semester in my independent study class.
Loading...
Similar Threads for Webpage Date
A subforum to comment preprints/webpages? Jun 21, 2004
