Textbook velocity problem
  • Thread starter sauri
Help please!!
I found this question in my textbook but the solution is not stated. A force of 2 N vertically down is applied to a vertical disc at a distance 2 cm to the right (horizontally) of the centre of the disc. The disc has a mass of 1.2 kg and a radius of 15 cm. Its initial angular velocity is 2 rad.s-1 anticlockwise.
How long does it take to come to a (momentary) stop?
I took a crack at it but is it correct?.
I=(mr^2)/2, I=[1.2x(15/100)^2]2. Then the value for I is substituted to F=Ia, where 2=value for Ixa, where a is found, and then substitute for a=w/t. So a is substituted=2/t and t is found.
Is this o.k?
Answers and Replies
Is this o.k?
The equation must be [itex]M=Fd=I\ddot{\theta}[/itex]
The M represents what exactly? and isn't the momentum for a disk about it's center I = ½ mr2?
Hootenanny
Staff Emeritus
I believe the M is turning moment or torque. Your F = Ia equation needs modifing, instead of using F, you must use torque:
[tex]\tau = I\alpha[/tex]
This is a version of Newton's second law.
I see, but is the working correct?
Is this o.k?
The first part is allright. After finding a(angular acceleration) you need to
use the eqn
[tex] \omega_{f}=\omega_{i}+at [/tex]
Now solve for t putting [tex]\omega_{f}=0[/tex]
I recommend you go through the eqns of motion for angular variables.
Edit:I didn't read ur sol properly.You also need to use [tex]\tau=Ia[/tex]
and substitute [tex]\tau=rF[/tex]
Hootenanny
Staff Emeritus
You are quite right arundg, it would be alot simpler using equations of motion, I didn't stop to consider the question, I was simply looking for errors.
I thank you all for your help. But could you tell me what the T in the equation T=rF stands for. Thanks again!
Hootenanny
Staff Emeritus
[itex]\tau = rF[/itex] is simply torque, force([itex]F[/itex]) multiplied by distance([itex]r[/itex]) from the axis of rotation.
and substitute [tex]\tau=rF[/tex][/QUOTE]
I understand using the [tex]\tau=Ia[/tex] part where we can find [tex]\alpha[/tex](angular acceleration). But why do we need to substitue [tex]\tau=rF[/tex]?. Why can we not just find [tex]\alpha[/tex], and find t so it can be substituted into [tex] \omega_{f}=\omega_{i}+at [/tex]
Hootenanny
Staff Emeritus
You need to use [itex]\tau = rF[/itex] and put it equal to [itex]\tau = I\alpha[/itex] to find the angular accelertatiion thus;
[tex]I\alpha = rF[/tex]
[tex]\alpha = \frac{rF}{I}[/tex]
Can you go from here?
got it.thanks
Hootenanny
Staff Emeritus
No problem
Related Threads on Textbook velocity problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
S
  • Last Post
  • Last Post
  • Last Post
  • Last Post
