Proof of the Cubic Formula
In summary, the conversation discusses the simplicity of the proof of the quadratic formula and the speaker's confidence in moving on to the proof of the cubic formula. The conversation also mentions the use of cubic roots and an equation to turn a quadratic into a cubic. The proof of the cubic formula can be found by googling "proof of cubic formula".
Char. Limit
The proof of the quadratic formula was so simple, I moved to the proof of the cubic formula with supreme confidence. And found myself awash in as and cs and cubic roots.
Can you turn this equation into a cubic?
[tex]x=-\frac{b}{3a}[/tex]
[tex]-\frac{1}{3a}\sqrt[3]{\frac{1}{2}(2b^3-9abc+27(a^2)d+\sqrt{(2b^3-9abc+27(a^2)d)^2-4(b^2-3ac)^3}}[/tex]
[tex]-\frac{1}{3a}\sqrt[3]{\frac{1}{2}(2b^3-9abc+27(a^2)d-\sqrt{(2b^3-9abc+27(a^2)d)^2-4(b^2-3ac)^3}}[/tex]
Googling "proof of cubic forumla" gives this proof.
First, the cubic equation: [tex]ax^3+bx^2+cx+d[/tex]. With [tex]x=y-\frac{a}{3}[/tex], you can reduce the equation to [tex]y^3+py+q[/tex]. [tex]p=b-\frac{a^2}{3}[/tex] and [tex]q=c-\frac{ab}{3}+\frac{2a^3}{27}[/tex]. In a cubic equation there are 3 possible answers, the one you listed would be one of the 3, [tex]X_{1}[/tex]
1. What is the Cubic Formula?
The Cubic Formula is a mathematical formula used to solve cubic equations, which are equations in the form of ax^3 + bx^2 + cx + d = 0. It provides a way to find the roots or solutions of these equations.
2. How is the Cubic Formula derived?
The Cubic Formula was first discovered by Italian mathematician Niccolò Fontana Tartaglia in the 16th century. It was later refined by mathematicians such as Gerolamo Cardano and Lodovico Ferrari. The derivation of the formula involves using a combination of algebraic and geometric methods.
3. Can the Cubic Formula solve all cubic equations?
Yes, the Cubic Formula can be used to solve all cubic equations, including those with complex roots. However, for some equations, the formula may result in complex or imaginary solutions.
4. What are the limitations of the Cubic Formula?
One limitation of the Cubic Formula is that it can be quite complex and tedious to use, especially for equations with large coefficients. Additionally, there are certain types of cubic equations, such as those with multiple roots, for which the formula may not provide accurate solutions.
5. How is the Cubic Formula used in real-world applications?
The Cubic Formula has various applications in fields such as engineering, physics, and economics. It can be used to solve problems involving curves, such as finding the maximum or minimum points of a cubic function. It can also be used in calculating the volume of certain shapes and in modeling population growth.
  • Linear and Abstract Algebra
